Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
The top rack - missing pin
The top rack (left side) the plastic part that keeps rack to metal has two pins that attach plastic to rack, well one has come off and lost - how do I get a replacement for this?
  • Anonymous Mar 24, 2014
    The plastic stem ware holder is in the way of the glasses. How do I remove it.
  • 159 Answers
At an appliance spare parts shop or by calling a number in the booklet that came with your dishwasher that you probably don't have anymore.
Posted on Jun 03, 2010
I have a brother xl5012 and would like to change the spool pin..not sure if its broken? the one on top is silver and the spare is plastic..not sure what to do..the manual has no answers.. thank you
On most machines, the spool pin simply screws into a threaded hole. If it was welded on or attached in some other permanent way, changing it may need a service visit. Brother has one of the very best service departments of any company I know. But try to unscrew the old one.. it might be stuck, a drop of penetrating oil, or maybe some pliers, might assist. If it comes out, a new one should screw in easily enough, so long as it matches the size of the hole and the threading.
Nov 17, 2014 | Sewing Machines
9VJL3 front panel
Do not have the Front Panel header pinout.
Do have;
Take an LED (Light), with two wires, and check the pins with it.
There is a Top row of pins, and a Bottom row.
Touch the first two pins in the Top row, left side. Does it light up?
No? Go to the next two pins. No? Go to the next two pins.
Keep going until the Power Supply comes on. (It is a BRIEF touch. The Power On switch is a Momentary Contact Switch )
Now you have the Power On switch pins.
LED light blinks? You have the Harddrive activity LED. (Light)
LED light stays on? You have the Power On LED. (Light)
Computer restarts? The Restart switch pins.
Short something out? NOPE. You can't hurt a thing using this method.
4 of those pins are for an internal speaker. (To hear BIOS Beep Codes with)
That's 12 of those 18 pins. (Probably less. It is two rows of 9 pins, that are stated for the Front Panel header)
4 of those pins probably won't be used.
You won't be using IR. (Infra Remote) (Only uses 2 pins, though)
Most of the time with an 18-pin Front Panel header;
Top Row:
Starting at Left side, going towards Right;
Pins 2, 4, 6, 8, 10, 12, 14, 16, and 18.
May be a pin missing in this row, or two.
Borrom row:
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Same thing here. May be 1 or 2 pins missing.
Pins 2 and 4 are usually for the Power On LED. (Light Emitting Diode)
Pins 6 and 8 - Power On switch.
Pins 10, 12, 14, and 16 may be for the Internal speaker.
Pins 18, and 20 are usually not used.
Pin 1 and 3 for the HarDDrive activity LED.
Pins 5 and 7 for the Reset switch.
Pin 9 is usually reserved for the factory, and is a 5 Volt test point.
Pins 11, 13, 15, 17 for speaker; or not used. Same with pin 19.
(So speaker pins may be top row, or bottom row. Dunno )
Another thing. This motherboard is old enough to be using a 3 wire LED, or dual color; for the Power On LED.
LED usually had the colors Green and Yellow.
Yellow for 'Normal' mode, Green for 'Turbo' mode.
(Which is a bunch of cr@p.
Green LED, or Turbo Mode; was actually NORMAL.
Normal mode was the computer operating BELOW the Normal mode)
So pins 2, 4, and 6, may be for a 3 wire Power On LED.
Regards,
joecoolvette
Dec 22, 2012 | Chaintech 9VJL3 P4(478)/VIA Motherboard
How to replace power button
1) Unplug from power
2) FOLLOW Anti-Static Precautions
[Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return ]
Gateway Support > Gateway GT4010 Desktop PC > Main Support page,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2809
Click on the Support Documents tab.
(Driver / BIOS / Applications / Patches / Support Documents / etc)
Click on the blue -> 5891 - Support Documents subheading
Click on Product Views.
Click on Rear View
Viewing the Front of your computer the Right Side Panel removes.
There are two Thumbscrews to loosen, shown by the letter C.
(They are supposed to remove all the way. If they do it's OK)
There is a finger-pull formed out of the back of the left Side Panel.
Pull towards the back of the computer. It should then swing out at the top, and can now be removed.
Go back one page, and this time click on - User Guides
Click on -
(This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up.
Took 10 seconds just now using a medium speed DSL connection)
Go to Page 51.
Now I would like you to go to Page 52 - Removing the front bezel
The Front Bezel is the Front Panel, of your computer.
It has 6 tabs that lock it on the metal frame of the computer case.
There are 3 of these tabs that you access, from the Side Panel opening.
It is only these 3 that need to be accessed, in order to remove the Front Bezel.
Looking at the inside, of the Front Panel, and the edge that meets the metal framework of the computer case;
One tab near the Top.
One tab in the Middle.
One tab towards the Bottom.
These tabs are plastic, and are formed out of the plastic Front Bezel.
Press the Top tab IN. (Not too hard or it may break)
Gently pull the Front Bezel towards the front of the computer, JUST A LITTLE.
Now press in on the Middle tab.
Finally press the Bottom tab in.
(Each tab has a flat hooked end. The tab itself goes through a slot, in the metal framework of the computer case. The tab must be pressed in far enough, so the flat hooked end will clear the slot, and allow the tab to slide through the slot; when the Front Bezel is pulled forward)
Tabs clear of the metal framework of the computer case; right side of Front Bezel swings out a little. (Viewed from the Front; Right side)
This will allow the tabs on the other side to release from the metal framework of the computer case.
NOTE*
It looks as through the Power On switch is attached to the Front Bezel.
This means use CARE, and ease the Front Bezel forward a little, away from the computer case.
Wires are still attached.
IF, you pull on the Front Bezel too hard, or too far; the wires may become unplugged from the motherboard.
IF, this happens, do not worry.
Here is the pinout information for all of those wires,
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553nv.shtml
For example; The Power On switch connects to the Front Panel header, on the motherboard. For this pinout click on -
W - Front Panel connector
9-pin header.
4 pins across the Top row.
5 pins across the Bottom row.
Starting on the Left side, going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the Left side, going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
(Light. It's a Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. 5 Volt check point reserved for the factory.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
IF the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
There is nothing(?) like removing a Front Panel (Front Bezel), and finding out you accidentally unplugged wires from the motherboard; and there is no pinout to connect them back.
Just makes you so HAPPY
!O_O!
Power On switch replacement:
The Power On Button is an assembly. Every pre-built computer manufacturer has their own design, and it can vary from MODEL to MODEL.
The main thing here is, the Power On switch usually doesn't.
This ATX power on switch is used in MANY models of Desktop PC's,
http://www.directron.com/atxswitch.html
I know it's hard to see here, and I apologize for that. Best example I have found.
View what looks to be a metal square cap in the front of the view.
There is a small post that sticks out.
This post is what the plastic part of the Power On Button assembly, presses against.
Power On Button assembly may have a plastic post itself, which is returned with a coiled spring, once the Power On Button is pressed.
Or the plastic button itself, presses against that Power On switch post.
You need to soften the plastic of the Power On Button assembly, in order to remove the Power On switch.
The plastic tabs of the Power On Button assembly may break, if this is not observed. Also compounded by the fact, that the plastic of the Power On Button assembly, has been heated several times, and is now brittle. (Plus age)
I use a hair dryer set on low, (Thanks honey. I'll be right back with it, lol!), and slowly wave the nozzle of the hair dryer, back and forth across the Power On Button assembly.
Once the plastic has softened some, ease whatever tabs you need to gently move aside a little, to ease the Power On switch out.
Be aware that the plastic will cool almost instantly, and need to be softened again, before attempting to replace the Power On switch.
Or perhaps june_sells20 this is the best way to go,
http://www.ebay.com/itm/Gateway-Brushed-Aluminum-GT-Series-5-Bay-uATX-Front-Bezel-8016758R-6378-/271069731471?pt=US_Computer_Case_Accessories_Tool_Kits&hash=item3f1d03da8f
Not advertising for seller, nor website. Just reference.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 12, 2012 | Gateway GT4010 (RBGT4010) PC Desktop
Needed to move motherboard to new case because of overheating / ventilation problems - do not know what the power / reset / hdd led leads are for the 9 pin f_panel (new case has each as separate...
Photo of the Asus M2N78-LA motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01421635&dlc=en
This photo also shows the orientation (Direction), that the motherboard is sitting in a computer case.
To the very bottom right is the Front Panel header.
The front plastic panel of the computer is the Front Panel.
The area of pins on the motherboard that the cables, (Wires) from the Front Panel connect to, is the Front Panel header. ( F_PANEL )
The Front Panel header, is the black rectangular shaped plastic block, that is sitting vertically on the motherboard.
Has two columns of pins.
4 on the left side, 5 on the right side. Makes it look as though there is a pin missing, at the top left corner.
I'm going to number the pins.
Pins on the Left side starting at the Top, going down;
Pins 1, 3, 5, and 7.
Pins on the Right side starting at the Top, going down,
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On switch. (Power On button)
B) Pins 5 and 7 are for the Power On LED light.
Pin 7 is for the Positive ( + ) wire.
(If the LED light is dim, reverse the wires around)
C) Pins 4 and 6 are for a Reset switch, IF a Reset switch is used. (Reset button)
D) Pins 8 and 10 are for the HarDDrive activity LED light.
Pin 10 is for the Positive wire. ( + )
(If the HDD LED light is dim when operating, switch the wires around)
Pin 2 at the top Right is NOT used. (NC. Not Connected)
I am looking at a motherboard manual in PDF file form, for the Asus M2N78-LA motherboard.
Regards,
joecoolvette
Sep 03, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
The spray arm, above the top rack, keeps unscrewing during the wash cycle. Just the arm comes off leaving a round plastic part attached to the top. This can be unscrewed and inside is a white 'washer'. The...
Could the arm be mounted upside down and rotating the wrong way? Just an idea... Some of these can fit either way and the retainer will fit either side of the arm.
Jun 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
How do you thread a singer 9836c machine
I have this machine and the manual but it will be difficult to explain without the diagram. Here are the instructions without the diagram ... I'm assuming that you know some parts of the machine i.e. the foot etc
NB. thread the bobbin FIRST - points number 8 onwards....
1. Raise take-up lever to highest position on machine by turning the hand wheel towards you and make sure the presser foot is raised.
2. Place spool of thread on the spool pin at the back making sure spool cap is firmly in place to keep it on.
3. Take thread and place through the thread guide (plastic bit same side as spool pin) a under and over action. Across from this guide is a small metal wheel on top of another loop pin on the top at the front of the machine. Take the thread and put through the loop pin. 9Thread should come out on top of the pin towards you).
4. On the front of the arm is a tension wheel numbered between 0 - 8. The thread should then be placed down the front of the arm, underneath the tension wheel (behind the body part of the arm not under the wheel) and lifted up to catch the tension spring unseen behind the wheel. It should then be threaded through the eye of the metal piece (that moves as the needle goes up and down).
5. The thread should then be passed down the gap in the body work and down through the middle of the metal spiral loop in the front near the needle.
6. The thread should continue down through the horizontal clip just above the needle.
7. The needle should be place with the flat part at the back and held firmly with the screw. The eye of the needle will face you. The thread should then be threaded through the front and out the back and under the foot leaving a six inch tail.
Your thread should now come off the spool move towards the left through the plastic guide, across the top of the machine at right angles, through the metal loop; down the front of the machine (you can't see the thread as it sits behind the body) and reappears through the metal arm hole that goes up and down with the needle. It should then come down through the metal spiral and behind the clip above the needle, through the eye of the needle and away from you under the foot.
8. The bobbin needs to be wound. The bobbins are particualr to each make of machine. So only singer bobbins can be used on Singer machines. The bobbin winder is the metal pin on the right on the top of the machine.
9. To wind the bobbin. Place the bobbin over the metal pin nad push firmly down. It is located on the top on the right hand side.
10. Place thread on the spool pin as before and thread the cotton through the plastic thread guide.
11. Take the thread as before but rather than going through the metal clip on the top at the front, place it anti clockwise partly round the metal wheel on top of the metal clip (don't go all the way around) and across to the right where the bobbin has been placed.
12. The thread should be wound clockwise as many times as required not to slip off when the thread is automatically wound with the electic foot peddle.
13. Push the bobobin manually to the right along the groove in the body and press the electric foot peddle. Bobbin should wind moving the thread up and down (not necessarly evenly) and filling the bobbin. Fill about 80%. Leave a six inch tail.
14 Pull the plate forward under the needle. Place bobbin in its slot. The thread should be in a clockwise direction and when the bobbin is placed catch the thread under the groove found on the left at the top of the bobbin case. Close the plate with the thread coming out above in the slot under the needle.
15 Manually turn the hand wheel a couple of times until you can see the bobbin thread making a loop with the stitch thread and pull through.
16 Both threads should be under the foot and away from you.
17 Tension normally is around 5 -6 on the tension wheel with standard cotton and polyester cotton thread. To tighten the tension the number should increment upwards.
Machine is a cracker and according to my local shop never goes wrong. I have had mine since 1999 and that's true.
Hope this helps.... I would send you the manual but I'm not sure how you keep email addresses private.
Good luck.
Jun 29, 2009 | Singer Sewing Machines
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Replacing encoder strip om Lexmark X6170
First unplug your printer...
Lift your printer top, like you are going to change your ink cartridges.
Unplug your scanner & control panel by disconnecting the 3 ribbon cables
Then, you will need a screwdriver (philips head). remove the screws (about 4) from the inside housing cover.
After you have this cover off...
You should be able to see the sides of the cartridge. Take your encoder strip (gently) and thread it through the back of the cartriidges. Note: There are small slits on the side where you can thread.
If the encoder strip has come completely off (there should be tension if it is connected), you will have to located the right and left "pins" to attach it back to. I have a lexmark x-2500 so, mine are on the metal frame. The right end (arrow up) attaches to a metal strip which points straight towards you (a part of the metal frame) with a small notch at the right end and on the left end there's a type of "punchout" pin which is a part of the metal frame. I had to slightly bend the right end pin to the right, just enough to create some tension & keep the encoder strip from popping back off. The left end pin should already be bent out to the left.
Hopefully, this helps someone
Feb 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
KitchenAid KSM90 gear stripped?
I just ran into this problem when the PLASTIC worm gear broke and then the mixer would not power on after I replaced the gear. The problem was due to the was I tried to dissasemble the mixer. I removed the two plastic screws near the top center of the mixer when attempting to disassemble. These do not have anything to do with the assembly it turns out the attached square pieces (attached to these screws by springs) must be in the proper orientation to run. I put them in the way it showed in a diagram but it did not work until I tried all four different combinations that they could be rotated. Two of the rotations on the square could be eliminated by closely looking at the end where it contacts the shaft. The round shaft marking will be evident on the square inserts. I'mnotsure how to better describe them, but the are attached by springs to the plastic screws on both sides of the top of the mixer.
May 31, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
73 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
