Question about Hotpoint WMA54 Front Load Washer
Drum is not turning
Hotpoint washing machine WMA54, the machine turns on and fills but the drum does turn, are the brushes on the motor gone
Will not spin drum not turning
Posted on Sep 23, 2010
  • Hotpoint Master
  • 3,463 Answers
Could be the brushes, only way to prove it is to remove the motor and check the brushes for wear.
If they are less than 3 or 4 mm long, then they need replacing. If brushes are o/k, then it is probably a control board fault.
Posted on Jun 03, 2010
My washing machine drum wont turn. The washing machine fills with water then just sits with water in it. It will drain but wont spin It worked fine yesterday, but today nothing. When I turn the drum by...
hello. if it don't turn then it could be the brushes on the motor also check the interlock on the door. any spin problems could be the module control board get back to me if you still have problems
regards
shaun
Jan 03, 2011 | Hotpoint WMA13 Front Load Washer
My machine hotpoint WMA54 takes the water but the drum does not turn, what could be the problem? thanks
Could be motor brushes in need of replacement.
To check them, remove lower rear cover of washer.
Unplug motor and remove earth wire, remove drive belt.
Undo 2 screws securing motor to drum, and lever motor off
the mounts
Replace brushes if less than 3 or 4 mm long.
If brushes o/k, then could be control board problem.
Check all connections between module and motor.
Please rate my solutioin.
Thankyou..
Feb 01, 2010 | Hotpoint WMA54 Front Load Washer
Loud niose coming from my machine when spinning
  • Hi,
  • Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | Hotpoint WMA54 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
WMA54 Hotpoint Aquarius flashing lights
My wife had the same problem last night.This morning when I turned the m/c on, there was a lot of noise and when I looked underneath, loads of sparking. Closer investigation shows I need new brushes and I imagine that if the drum on your machine is not turning, you do too.
However you said that you can hear the motor? That may indicate a belt problem instead. get someone to turn the machine on it's side and manually turn the drum. If the motor rotates it isn't a belt problem and someone needs to test/repair your motor.
Hope that helps a little.
Jon
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA54 Front Load Washer Logo
252 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
