Question about GE SMR03BASWW Compact Refrigerator With Ice Box
GE SMR03BASWW Compact Refrigerator With Ice Box; compressor does not run. How do I determine whether the problem is in the relay or the thermostat or elsewhere?
  • 1314 Answers
SOURCE: GE Refrigerator Compressor Inop.
what the good doctor is saying is check for voltage where the wires come into the ptc reley thats a great idea
Posted on Jan 22, 2008
  • 184 Answers
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Posted on Apr 10, 2008
  • 163 Answers
SOURCE: GE refrigerator TDX11SNYAWH.
check your defrost timer and see if it is stuck in defrost.
Posted on Mar 07, 2009
  • 1218 Answers
SOURCE: Compact Refrigerator stop cooling, I am out of ideas.
Good day,
If you hear the compressor running, then the overload and relay are O.K. It can be one of three things.
1. Leak developed in system.
2. Restriction internal in the refrigerator sealed system.
3. Valves in compressor failed, which would not provide any pumping action for the refrigerant.
None of these items are practical repairs on a compact. But if it's under warranty (under 5 years old), check with the selling dealer for warranty claim.
P.S. Does not apply if coils were punctured.
Thank you for using FixYa
Posted on Jan 16, 2010
SOURCE: GE TBX25ZLB Refrigerator Compressor won't Engage
Part number for compressor relay is WR7X222. However, you have a very old rotary compressor there and most likely it went bad. I would just buy a new fridge. Don't waste your time/money. The fridge is too old.
GE refrigerator repair in orange county, ca
Posted on Feb 06, 2010
Ge turbo cool fridge doesn't cool.
If your refrigerator is not cooling, the problem could be as simple as a covered vent or something more complicated that requires the help of a service professional.
Is your thermostat set incorrectly? It's possible to accidentally bump the thermostat, so check it and reset, if necessary, to the proper coolness.
If there's ice on the evaporator cover ( typically found on the back wall), it's a sign that the evaporator coils inside could also be covered in ice and frost, indicating a defrost problem. Try unplugging the fridge and defrosting it before calling for help.
Since you are hearing no unusual sounds, the problem could be the start relay, which triggers the compressor. Have a refrigerator repair pro determine if the start relay is the culprit and to replace it if necessary.
For more help identifying the causes and solutions, read Refrigerator not cooling or check out the video below. I hope this helps!
Sep 27, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Looking for shelves for my smr03basww compact refridgerator.. can anyone give me some low cost places to find them? I really appreciate this!! Lynn
Lynn,
Try any of these: www.repairclinic.com, FixYa.com advertiser, your local appliance repair parts distributor or appliance shop, your local hardware store.
Thanks for your quesiton @ FixYa.com
Aug 15, 2011 | GE SMR03BASWW Compact Refrigerator With...
I opened the refrigerator and its no longer cold in there, both sides.
Greetings,
The first thing is to determine if the compressor is running...if its off and not running..remove rear cover...if you hear a clicking noise once every five minutes or so...The relay may be bad...this is the part that fits on compressor terminals. remove it and shake it..if it rattles...its bad, it could even be bad and not rattle, but they usually burn out and rattle...okay, now if compressor is cold and nothing comes on..it could be off thru the defrost control or thermostat. I'm betting , its a burned out relay
Jan 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hello, my girlfriends 2002 kenmore refrigerator stops cooling after a few hours of being plugged in. Replaced the thermostat, replaced the fan, and replaced the computer board (which I thought was the...
The compressor feel hot to the touch after she quits? Could be a bad compressor relay. The ice box might have a fancy control but it still has relays just like the older ones. themobilian_256.jpgthemobilian_257.jpg
Nov 24, 2010 | GE GDS20KBS Bottom Freezer Refrigerator
Mini Fridge freezing everything
Yes, thermostat and when they go bad they eiter sop , keepgetting colder or out of calibration, I will see if I can find one, Really any small two wired refrigerator thermostat wil be fine, Sea Breeze
Mar 18, 2010 | GE SMR03BASWW Compact Refrigerator With...
Good day,
Jan 16, 2010 | GE GMR02BAN Compact Refrigerator
My GE Compact Fridge doesn't start up, even though I left it standing upright overnight and turned the temperature dail clockwise. Yes, it's plugged in. :)
Ok so I will assume from your post that you turned the dial completly to the coldest setting and that the compressor does not come on (nothing comes on, no fans no compressor). Did you just plug it in and attempted to start it ? There is usually a delay in starting your compressor, it should come on within 10-15 minutes - if not, try turning the dial back to off and then turn it back towards the coldest - do you hear any "clicking" where the dial is at (thermostat) ? If it does not start you may have a compressor relay problem or control board problem - But for your compact refrigerator I would say more likely a bad compressor or relay / capacitor, etc.
Sep 05, 2009 | GE Refrigerators
Build up of ice
YES
The thermostat is not cutting out.. It needs to be replaced.. Your compressor risks burning out if its is continoulsy running ...
Nov 14, 2007 | Hotpoint RLA30 Compact Refrigerator
GE SMR03BASWW Compact Refrigerator With Ice Box Logo
78 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
