Question about Lionel The Polar Express Train Set
My lionel train won't run at all. What do I do? It won't run,it's whistle doesn't work,and the bell doesn't work
    Problem Solver:
  • 13 Answers
Bad connections, wires to/from the transformer, or maybe a real dirty track.
try spraying a very small amount of CRC [brand ) 226 it is better than any contact cleaner on the market. do not get it on the rubber traction wheels on the engine. If you do, wash off with alcohol using a cotton swab on the rubber band on the traction wheel.
Posted on Nov 20, 2011
Did you ever solve your problem? My son is having the same problem.
Posted on Dec 05, 2010
  • 34 Answers
Are you in fact getting power to the track? If you are using the CW-80 transformer that comes with the Polar Express set, the fuse is inside the case. (a major design error). Sounds like the fuse is shot. Another check for power is to put one of the passanger cars on the track. If it lights up then the power is OK. The electronic board in the loco may be bad.
Posted on Oct 05, 2011
Lionel 2466WX Tender -- HOW do I get it to WORK? (Assuming that it does work)?
Good work, Dan! Fixing trains can be as much fun as running them.
Apr 22, 2014 | Crafts & Hobbies
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
The whistle on either side of my 1966 lionel zw transformer does not work
The contacts on the switch may be dirty but the most likely problem is that both selenium rectifiers are dead. Replacement silicon rectifiers are available if you want to do the repair yourself. Check the internet for suppliers. You can get the ZW repaired at most good Lionel service centers for a reasonable price. Get a list of service centers by searching on-line or at Lionel.com.
Mar 05, 2014 | Crafts & Hobbies
Lionel train problems
Make sure the A or D terminal is connected to the center rail. U terminal to the outer rail. First do this without the sound activation button. Horn should sound this way. Once this works correctly, add the sound button in on the center rail lead (A or D) If the sound activation button activates the horn, reverse the connections to the sound activation button.
This should solve your difficulties
Dec 04, 2013 | Crafts & Hobbies
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
I am trying to hook up a Lionel 1033 transformer to my Christmas train. What terminal goes to what? I want my old 2026 to smoke and my 6446W to whistle.
I have the original Instructions for Operating the 1033(written in 1953) - the second paragraph of the "How To Connect Transformer" reads as follows: The "Multi -Control" transformers listed in this leaflet have four binding posts located on the top of the transformers. Of these, "A-U" and "B-U" combinations furnish variable voltage for the track. The control arm of the transformer simultaneously regulate the voltage output of both the "A-U" and the "B-U" combinations. The transformer nameplate indicates the voltage ranges of these two combinations.The "A-U" combination supplies any voltage from 5 to 16 volts. The B-U combination has voltage from 0 to 11 volts. In selecting the proper range of voltage for your particular outfit, try the lower "B-U" combination first. If the maximum train speed is not satisfactory, then try the "A-U" posts.
To paraphrase the "How to Connect Accessories" section: accessories work best with fixed voltage - these voltages are obtained from the following pairs of output binding posts: "A-B" 5 volts; "B-C" 11 volts and "A-C" 16 volts.
Hope this helps, Mark
Dec 14, 2009 | Toys
Why is a ''D'' battery needed for my Lionel Diesel engine?
This is just a guess but it may have powered headlights or other lights on the train at one time, some of then even had a smoke producing device on them.
Mar 19, 2009 | Lionel New Haven Freight Train Set
Lionel The Polar Express Train Set Logo
3,714 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
