Question about Anycom HCC-250 Bluetooth Headset
Pairing instructions and code for pairing
    Guru:
  • 868 Answers
Paring what? please complete information thanks ^_^
Posted on Jun 04, 2010
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
Apr 26, 2017 | Televison & Video
Got a new phone can't find the pass code
The pass code for the first time user for the headset is 0000(four zeros).
Here is the pairing instructions link:
http://www.headsetsdirect.com/plantronics-explorer-220-bluetooth-pairing-instructions
Good luck from Headsets Direct - 800-914-7996.
Aug 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
When getting paired tells me code is wrong...help
Correct. The pairing code is 0000. If you need instructions on how to pair, please let me know and i will be glad to assist you.
Mar 25, 2010 | Motorola Mobility H500 Wireless Headset
I have 220plantronics bluetooth and I need code to pair with my blackberry
The default pairing code for this headset is 0000. Please let me know if you need pairing instructions.
Mar 25, 2010 | Plantronics - Bluetooth Headset Plus Base...
I lost the instructions that contain the unlock code to enable bluetooth access... I got one of those bluetooth adapters for my computer and i'm trying to pair my computer with my mobile phone. My phone is...
If you want to pair the phone with the PC through BT then all you have to do is to give and number like 00 or 0000 as the code. on the phone and press enter. Then the PC will ask for the code. You should give the same number there too, ie, 00 or 0000, whatever you gave earlier. Then the phone will connect to the PC through BT.No instruction manual is required for this. Once your phone and PC are paired you can set then to connect with out this code being given every time.
Dec 04, 2009 | Computers & Internet
It doesn't let me punch in the code of 0000. other phones are easier to pair.
Go to settings/ pair with phone/ other phones. it will then give you the code to use, then search for new paired device from your phone, when it finds parrot, click pair and enter code shown on parrot screen. Make sure you delete all other paired devices from parrot first. instructions can be found at parrot.com
Oct 30, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
What is the pairing code for these headphone
The pairing code is simply 0000. It is written in the instructions manual.
Oct 07, 2009 | Itech Radio Communications
Explorer 320 pairing to motorola v323
i was giving a bluetooth with no instructions or codes how can i connect it with my unlimited boostmobile phone
Nov 01, 2007 | Plantronics Explorer 320 Wireless Headset
Blue tooth device pairing code
open bluetooth and search for new device,when you find new device you can configure it so as no code is required and pair auto
Oct 18, 2007 | Magellan RoadMate 6000T Bluetooth GPS...
Anycom HCC-250 Bluetooth Headset Logo
667 people viewed this question
Top Anycom Radio Communications Experts
Michael Vincent Cruz
ray gallant
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
