Indesit 1200 washing machine boils everything and
Indesit 1200 WIDL126 washing machine boil washes everything at 30 degrees and then stops spinning, any ideas?
    New Friend:
Probably the NTC temperature sensor is faulty. This is a circular device with 2 terminals fitted into the rear of the drum just above the heater element. This is easily checked if you have access to a multimeter. Just remove the connectors and measure the resistance with the multimeter. The value measured should be about 20Kohms at 20 degrees centigrade (ave. Room temp).The sensor is easily replaced. Just carefully prize it out with a blunt implement. Fit the new one using a small amount of liquid soap applied to the grommet. Take care not to damage the grommet or it will leak. The sensor costs about 10 pounds
Posted on Oct 23, 2013
Make sure you have connected the cold water feed and not a hot water supply, these machines need a cold water feed only
Posted on Jul 27, 2010
Washing machine boils my clothes when I select a 30 degree wash
your mixing valve needs to be replaced iis what brings the cold water in to cool the hot water off, depending on the unit you will have to ask the company but it might be the heat sensor beings alot of newer machines have computer boards
Jun 09, 2009 | Washing Machines
INSTUCTION MANUAL REQUIRED
This online company list all Indesit WM manual:
http://www.unbeatable.co.uk/manuals/Indesit-Washing-Machines/27916330.html
From them:
Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
no_image_large.jpg Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
May 26, 2009 | Indesit Washing Machines
Indesit washer wil 103
Check your water inlet valves. Seems like the valves have went away. Also check the computer board and inline fuse to make sure everything is correct. Inlet valve are located behind the supply line hoses. Please rate. Thank you
Feb 14, 2009 | Indesit W 123 Front Load Washer
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
My bosh exxel 1200 express rises but wont spin
I killed three nuns put them in a pot boiled them and then made soup gave that to my washing machine and it now works fine. Would recomend to anyone!!!!
Nov 04, 2008 | Washing Machines
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
I have a indesit WIDL126. Half way through through the drying cycle all the lights on the buttons start flashing and it stops spinning. I can still hear the motor working but all I end up with is a machine...
I have had the same problem and this has worked in the past:switch off the machine, then unplug it at the mains. Leave it unplugged for about a minute then plug it back in and try again.
Mar 04, 2008 | Washing Machines
Washing Machines Logo
345 people viewed this question
Top Washing Machines Experts
