Question about Edimax BR-6104K Router (br6104k)
Unable to login to the router's admin
When trying to login (admin, 1234) the login popup stays on as though it does not receive the password
    Sergeant:
  • 356 Answers
Hi there!
Try resetting your router. There's a reset button at the back of the router. Press it for 10 seconds to reset it to factory settings. You should be able to connect to your router without being asked for a wep key or password.
Happy surfing!!!
^_^
Posted on Jun 03, 2010
  • Farid Aug 01, 2013
    Well such a behavior is a repetative issue and each couple of weeks i have to reset the modem and reconfigure it again to be able to access the modem i believe its not the ideal solution that can be provided and knowing the root cause is the way to solve it rather than doing such workaround
Unable to set up wireless service to my router
Without additional info. Check some of the basics.
With you user manual or perhaps info found on your router log directly into your router thru your browser. If you can't find the IP for it anywhere on a label or in your literature try typing192.168.0.1 into your browser and hitting <enter>
Sometimes the default IP address is found on the router label if that doesn't get you to the login screen for the router. If you get to the login screen, your default User ID and password is often ADMIN, then ADMIN again. Once there you need to get into the wireless settings setup or find your SSID. (Your Wireless Network Name or technically your Service Set ID) Exampe: JohnsHouse Then you need to find or set your Pass key, sometimes called pin or password. Example 1234. These two things need to also match in the settings on any WiFi device you are attempting to add on to your network, such as a smart phone, tablet, or other WiFi device.
As with making any changes, write down the before and after settings of anything you change. Make sure to save when you are done. If a change doesn't work at least go back in and change things back to the state they were before you started. Additionally most routers have a reset that will change everything back to default factory settings. Doing that may change settings you have not written down. Those settings including the admin User Name and password. Everything will change to that factory default. The reset is usually found as a small hole that you depress a tiny button using the end of a paper clip or ball point pen. If you don't know what you are doing I don't advise resetting your router though. If you are still unsure I suggest contacting tech support for your specific router. They should be able to walk you through it on the phone.
Dec 09, 2013 | Zhone 1518-A1-NA Wireless Broadband Router...
My edimax wireless access point is saying i have the wrong username and password and wont let me login
For most Edimax routers, the default IP address is 192.168.2.1, default username is admin and password is 1234.
By default the router is a DHCP server which will assign IP address starting from 192.168.2.100 to 192.168.2.199 to DHCP clients automatically.
Make sure your computer has TCP/IP Protocol setup as "Obtain IP address automatically".
Open the Internet Explorer.
Type in http://192.168.2.1 hit Enter.
The Login window will appear.
Type in the default username admin, password 1234.
Click on Login.
Then you can configure the router.
Sep 11, 2013 | Edimax Computers & Internet
Forget my router password
if you forgot your wireless password or your router password then you can login to your router from your browser by going to 192.168.0.1 the default router login is admin/password or 1234.
go to wireless and then you can change your security password.
if you are unable to login to the router from a browser then you will need to reset your router to factory settings by holding the reset button in with a paper clip for 30 seconds while powered on. then login and reconfigure your settings. you will need to reconfigure all your wireless devices to join your wireless network after this is done.
Feb 23, 2012 | D-Link Computers & Internet
Forget router password
the default login for netgear routers is user name = admin and password = password. for older devices it is 1234.
if you are unable to login. you can reset your router to factory settings by holding the reset button in with a paper clip for 30 seconds with the power on.
Feb 15, 2012 | NetGear DG834G Router
Where is password on this box
I assume you mean the login password for the box.
Depending on the version of the Box, the default password / login combination is this:
Username: Admin
Password: password
OR:
Username: Admin
Password: setup
OR:
Username: Admin
Password: 1234
If however, the password has been changed at some time, you will have to reset the router using a paperclip. THIS WILL RESET ALL SETTINGS so use as a last resort.
Mar 15, 2011 | NetGear WGR614 Wireless Router
I was unable to login as admin in my dir600 dlink router...but i can login as user...how can i login as admin?
The default admin username is "admin" with no password.
The default adress is http://192.168.0.1
If you are still unable to connect, the password may have been changed. Reset the router with the button on the back, and try again.
Feb 27, 2011 | D-Link DIR-600 Router
Don't understand how to set password. please help
Plug the router into the power socket and configure you own machine to obtain IP address automatically. Load up Internet explorer and type in http:/192168.xxx.xxx which is the local address of your router. You should then get a password screen. Enter default user name and password and it will take you to the configuration screen. The full IP address and user name and password are dependant on which model you have. See list below From there you need to read the instructions very carefully and match it with the information provided by your ISP.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
? Q: What is the default IP address, username, and password for routers? ? A
ZSR0104
192.168.8.1
Administrator password: admin
ZSR0104M
192.168.1.1
Login password: No Password
ZSR0104B
192.168.1.1
User Name: admin
Password: 0000
ZSR0104AS-01
192.168.8.1
Administrator password: No password
ZSR0104E
192.168.2.1
ZSR0104CP (Grey color)
192.168.1.1
User Name: admin
Password: admin
ZSR0104CP-05 (Blue color)
192.168.10.1
User Name: guest
Password: guest
ZSR0104WE-01
192.168.2.1
ZSR0104WE-04
192.168.2.1
User Name: admin
Password: 1234
ZSR0104WE-05
192.168.1.254
User Name: admin
Password: 1234
ZSR1104WE
192.168.2.1
User Name: Empty
Password: Empty
ZSR0104DE
192.168.2.1
ZSR0104FS
192.168.1.1
User Name: admin
Password: admin
ZSR0104UP
192.168.1.1
User Name: admin
Password: 0000
Dec 22, 2010 | Zonet Computers & Internet
I am unable to login and the reset does not work
Bro you can reset your configurations bro in order to go back to the default setting of your router. default ip address: (http://192.168.0.1), user name: (admin), password: (default password). follow the image shown bellow. 6f8fc35.jpg
May 15, 2010 | Computers & Internet
Cannot login and have reset....
use the console cable . By using this u can able to go inside the router and after going inside just give the respective IP and after giving the ip to the router u can access the router by using Internet Explorer .
Jun 02, 2009 | NetGear DG834G Router
Cannot connect to admin interface of Netgear RP114 router
The default is
username: admin
password: password or (for older routers) 1234
If this didn't work try to reset the router. Here's how;
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
Then Configure the router;
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.0.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password" or ( for older routers) "1234".
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
Apr 10, 2009 | NetGear RP114 Router
Edimax BR-6104K Router (br6104k) Logo
536 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
