Question about Maytag 7.0 Cu. Ft. Electric Dryer
Dryer makes loud noise during drying cycle. Drying is fine otherwise.
    President:
  • 512 Answers
Bearings in the drum rollers going bad or something caught in felt area of drum. Need to take dryer apart to figure which it is.
Posted on Jun 04, 2010
Dryer makes loud noise and does not spin
had that problem once and it turned out to be 2 problems....the first was the belt that snapped..replaced it and it did not work turned out to be the pulley on motor broke
Dec 17, 2011 | Dryers
Model #MCE8000AYW Maytag Drying Center - The bottom dryer has started making loud noises. It doesn't seem so bad when the dryer has a full load' but as clothes are taken out and the dryer has a...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 30, 2011 | Dryers
My LG Front-load dryer is making a loud noise during the drying cycle. If i press on the lower left front panel - the noise is muffled quite a bit. Model # DLE5977
heatman101
gfg
Sep 27, 2010 | LG DLE5977 Electric Dryer
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Loud screeching noise from dryer.
sounds to me like the nylon pieces that isolate the drum from the front of the door are gone, you may want to open it up and take a look at it. Is it an old dryer? Its either that or I suppose it could be the bearing in the middle of the back but I dont think it would be in only certain parts of a rotation, it would be all. Im sure the drum probably just ate through the nylon seperator.Theres not much else that only makes noise part of the time.. and theres not many moving parts.
Im not sure if there are replacement pieces for this but you can google it.
Apr 13, 2009 | LG DLE2532W Electric Dryer
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
Loud/Soft signal
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
May 25, 2007 | Kenmore 67052 Dryer
Maytag 7.0 Cu. Ft. Electric Dryer Logo
316 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
