Question about Kyocera Copystar CS-1820 Black and White Copier
Paper jam 40 - Kyocera Copystar CS-1820 Black and White Copier
    Problem Solver:
  • 3 Answers
Its a misfeed in the fusing section. The paper didn't get to the exit sensor after the registration roller by the drum was activated. Check the fuser and drum areas. It can be caused by a dirty exit sensor, registration rollers not having pressure, a bad fuser roller or drive gear, or the exit rollers not making good contact.
Posted on Jun 04, 2010
  • 3 Answers
It Can Also Be That the solinoids have sticky pads
Causing the same error as a 40 Jam from cassette and 20 Jam from MP tray
To fix these I recomend you replace pads on the Pickup, registration and MP tray solinoids
Remove the covers on the right side
remove the control board connectors on the left looking in that side held on with three screws
you should see 2 of the solinoids then
and there is another solinoid under a tan cover right below those solinoids
remove the old padding, and put in new padding
that will fix those sticking solinoids
the pads act as a damper for sound as well as helping to push the claw back out because the springs may not have enough pull to return them home
bernielhat
Posted on Dec 02, 2011
Says paper jam but isn t one
It could be as simple as the rollers being dirty and its detecting a timing jam. or it could be that the exit sensor detection arm is stuck or sticking . if it was stuck you couldnt put another document in with out opening and closing the lid it would say jam. really sounds like its really dirty. now if it will run one with no problem its the seperation pad or roller depending on model. it tries to pull other sheet and it fails and shows jam but no paper in the unit . clean your rollers with wd-40 let sit few minutes 2 or 3 and retry. ya i said wd-40 you will be amazed.
Feb 17, 2014 | Canon Office Equipment & Supplies
Paper jam out cassette
Odds are you are going to have to replace the paper pick up & paper feed and sep. rollers. You can also, try to clean the rollers with a rag with a very little bit of WD-40 and clean the three roller and dry off the WD-40 and see if that solves your problem. Good Luck
Jun 08, 2012 | Muratec Mfx-2500 Copier Scanner Fax...
I have Kyocera Copier that is trying to print a fax and it keeps coming up JAM 40. How do I fix this?
JAM 40 is a fuser jam. Remove the process unit and make sure there is no paper there. Open the back cover and make sure there is no paper there. Turn the machine off then back on. If you are still geting Jam 40 then you have a bad sensor or similar issue.
Jun 10, 2011 | Kyocera Copystar CS-1820 Black and White...
Paper is getting jammed when printing is commenced , I am using cl-41 color and pg-40 black cartridges
paper can jam up if paper is too loose in tray dosnt go in square to the printer, too much in tray,,the roller not pulling in the paper evenly paper damp and sticking together
Jul 06, 2010 | Canon PIXMA iP1300 Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Paper jam due to water condensation in fuser unit Optra C710
The problem is that you have paper that contains too much moisture. (I bet it's been in the printer for a long time and has absorbed moisture form the atmosphere.. has it been rainy lately? When the moist paper gets heated in the fuser, the excess moisture turns to steam which then condenses back to water
on paper guides etc. Your diagnosis that the water is causing the jam is correct.. Try using some dry paper and it should be fine.
May 27, 2009 | Lexmark Optra C710 Laser Printer
Dell 1700 printer paper jams
if the paper is jamming at the back of the unit, and looks like an accordian after removal, it's more than likely only the paper sensor on the fuser. i dont recall the part number, but it can be had from online suppliers for under $40.
Nov 10, 2008 | Dell 1700n Laser Printer
How do i remove a stack of paper jammed in my printer
refer to manual - all else fails pull backwards canot harm now-
Nov 07, 2008 | Dell A940 All-In-One InkJet Printer
Carriage Jam
It is making a horrible loud clicking noice. The visual says carriage jam. There is no paper jam. What do I do?
Jul 28, 2008 | HP Office Equipment & Supplies
Machine shows "Paper Jam" error
There is a paper senser present in the paper lifting area. That part of your printer is not working properly. Replace that part and then try
Sep 20, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Kyocera Copystar CS-1820 Black and White Copier Logo
1,484 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
