Question about Microwave Ovens
My Fagor oven and hob is blowing the circuit breaker, what is likely to be the problem please
  • soosywhit Jun 04, 2010
    Thankyou, I will take your advice
  • 360 Answers
the problem is over loading. The Oven and Hob plus other electric appliances/equipment are all overloading the circuit breaker. The circuit breaker is too small for these appliances or the circuit breaker cannot carry them all, that's why its blowing.
You need to change the circuit breaker to a higher one, that is, to the one with a higher capacity that can carry the oven and hob.
I would further advice that you call an electrician to help you check all the appliances that is loading the circuit breaker and recommend a breaker that can carry your electric appliances. This will determine the capacity of breaker that you need to buy.
Take care.
Posted on Jun 03, 2010
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
Blowing breaker microwave intermittent
The microwave only draws a lot of current when cooking and on, you may have either a bad breaker or another item on that same circuit causing this, Fridge?
Dec 21, 2012 | Microwave Ovens
I don't know if it is the microwave that blowing the circuit, but that is what my brother said. It blows the circuit sometimes when they use it. Model# MS-104yc 1.5KW or maybe the combination of the air...
Are you referring to tripping the breaker? The microwave runs on 110 volts, and if you are referring to a central HVAC unit, it runs on 220. No way the one could blow the other, unless you are referring to a window unit. If it is tripping the breaker, you could start by replacing the breaker (can buy at Home Depot or Lowes), and if it still continues to trip the breaker, then it is more than likely the capacitor.
Jul 30, 2010 | LG LMV1630 Convection/Microwave Oven
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
How can I get the power to come on my Sharp microwave?
The problem may be an electrical one. Microwave ovens require a lot of power. Often, they use most of the power available to the circuit they are plugged in to. If there is not enough power in the circuit to feed the microwave and whatever else is plugged into that same circuit the fuse will blow or the circuit breaker will kick off.
Go to your electcical box, and check the breakers or the fuses. If one of the breakers has kicked, reset it by pushing it all the way off and then back on. If the fuse is blown, unscrew it and screw in a new one of the same amperage.
good luck. please rate my answer. thanks
Feb 12, 2009 | Sharp KB-6015K 1000 Watts Convection /...
Keeps blowing breaker
Did you call Samsung's Service Division at 800-932-3837?
They may be able to give you a better number to call.
If you don't have them, you can download Samsung over the range microwave installation instructions here.
Please let us know what you find out.
Oct 22, 2008 | Emerson MW8987B/W Microwave Oven
Microwave Sylvania type sm81001
Have you ever replaced the fuse with Higher Amps fuse. There is a circuit diagram inside the cover please refer to that and ensure that the rating is same.
Jan 04, 2008 | Sharp R-1480 Microwave Oven
Randomly blows circuit breaker while not running, only the clock is on.
Normally when the circuit breaker blows, it a bad door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 03, 2007 | GE JES1358 Microwave Oven
Jenn-air model jmc7000
Can someone tell me where i can find fuse for microwave convection/grill oven 5kv 700ma There is a other no on the fuse TUV5m41GF
Aug 29, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
