Question about XM Radio (XMP6000)
Xm radio how do you know if your vehicle radio is xm compatible or not? Does everyone have to buy all of the attachments, etc? Thanks
  • 113 Answers
If you have a dual xmp6000 your radio has xm built in. If you bought it new it came with the antenna- all you would have to do is activate it-www.xmradio.com. or call 1-800-967-2346
Posted on Apr 09, 2008
I had the same problem. I contacted the XM Radio people and was told I'd have to buy a new radio (with all the cables, etc) and pay a $75 transfer fee. This sucks since I am not transferring the radio to...
You should not have to pay a $75 transfer fee unless you have a lifetime subscription. Was your radio still under warranty? If it is under warranty, they should send you a 'used' refurbished unit at not cost to you. They MIGHT charge you $15 to TRANSFER your subscription, but usually won't if you ask them nicely. Can you give me more details on exactly what is and what isn't working with your radio? Thanks, John
Oct 03, 2010 | Delphi XpressRC XM Satellite Radio...
I have a XM Model 136-4335. I need an operators manual. I need to program preset stations and don't know how. Thanks, Mike
The XM model number provided is branded DELPHI but is actually made by AUDIOVOX... a manufacturer that is commonly rebranded XM, TERK, RCA, etc. So the Audiovox manual is what you need. Now since Audiovox usually doesnt support directly its hard to get manual from them directly. The link to your manual (the third down on this page and the picture looks a bit diffferent but is the silver receiver not black box ones) Good luck
http://www.retrevo.com/support/Audiovox-XM-Satellite-Receivers-manual/id/395ag115/t/2/
Jun 02, 2010 | Delphi XpressRC XM Satellite Radio...
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
How do I get to channel 210? When I turn the knob on the radio (2009 Mercury Mariner) it goes from 194 to 0.
Channel 210 is MLB Home Plate, which is part of the "Best of XM" package. If you haven't subscribed to Best of XM, which costs extra on top of your Sirius base subscription, then you cannot receive that channel.
Additionally, only certain radios are "Best of XM" compatible.. The fact that your car is a 2009 model.. While I don't know what radio it has in it.. I would assume it is a newer model radio that does have Best of XM capabilities, so the problem is most likely that you do not have the Best of XM package.
http://www.sirius.com/bestofxm
May 03, 2009 | Sirius Satellite Radio Receiver
I don'tknow how to use the satellite radio...
Got this off the crutchfiel web site.
Item #700XMSON1 $129.98 This XM Direct 2 package includes everything you need to add XM Satellite Radio to your compatible Sony receiver: an XM Mini-Tuner, a CNP2000UC universal adapter, and a Sony connector cable. The Mini-Tuner connects to the universal adapter, then you use the connector cable to hook up the adapter to your Sony receiver.
Use your home computer to program the universal adapter for your Sony receiver — you can reprogram this adapter to work with another brand in the future. Once connected, you'll be able to change channels and see programming information on your stereo's display. You can also use the included XM Mini-Tuner with your XM-ready home receiver or in another vehicle with a compatible dock.
A computer running Windows XP and Internet Explorer is required. The unit is not compatible with Windows Vista.
Note: A subscription to XM is also required — learn about XM's programming. Satellite radio service is available only within Canada and the lower 48 states — not available in Hawaii or U.S. territories. Portable reception may vary by location. If you have questions about the proposed XM/SIRIUS merger, read the XM Customer Promise. To view this file, you will need the Adobe Acrobat PDF reader.
Apr 16, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
My stereo has xm radio but does not give me that option when i press srs it only gives me radio and to play cd
you have to buy another unit to hook up to your deck, your deck is compatable with xm but does not have it, my jvc is good for both kinds but i have to buy a brain for it then the radio unit as well.
Oct 08, 2008 | Pioneer Car Audio & Video
Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
Jul 17, 2008 | 2007 Honda Odyssey
XM Radio Receiver
Go to www.walmart.com and type in the search box XM Radio. Walmart carries a XM Docking Station that is capatable with most units. FYI though XM has merged with Sirrus so XXM will still work but will soon be unbuyable.
Jun 18, 2008 | Alpine CDA-7897 CD Player
FINDING A RADIO FOR A SEMI TRUCK
Those measurements are a standard single DIN automotive radio.
You need to find a "XM ready" or "With XM controls" radio and install a separate XM receiver box. For example this would be the in dash deck:  http://www.crutchfield.com/App/Product/Item/Main.aspx?o=p&showAll=N&g=300&i=158XRCA350&tp=5684 And this is the XM receiver: http://www.xm-radio-satellite.com/index.asp?PageAction=VIEWPROD&ProdID=3951
I would suggest finding an in dash receiver that also does HD radio as well as XM.
May 16, 2008 | Car Audio & Video
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Aug 26, 2006 | Delphi Roady2 SA10085 XM Radio Receiver...
Car Audio & Video Logo
99 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
John
John
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
