Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Dishes/cups are not being completely cleaned. there is grit in the cups on the top rack, along with coffee stains still in the coffee cups. i sometimes pre-rinse, however, i didn't have to w/ my previous dishwasher. any suggestions would help.
  • 70 Answers
1)check the enough inlet water pressure. 2)check any block in the rinse nozzle. 3)check it attains the temperature. 4)check proper detergent& sanitizer going.
Posted on Jun 03, 2010
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
Dishes in top rack not getting clean
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
May 28, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
The dishes are not getting clean on the lower rack even after several washes. What can be done?? The top rack comes out clean. It almost seems that the water flow on the lower rack is limited. Something as...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | LG LDF6810ST Stainless Steel Built-in...
Dishes not coming out clean
Apr 02, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
The dishes on the top are not getting clean what can be the trouble? Tea stains and grit are left in cups and glasses.
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Dishes not getting as clean as they used to
RUN A EMPTY LOAD ON HOT WITH A COFFEE CUP FULL OF VINAGER SITTING ON THE TOP RACK, THIS WILL CLEAN THE DISHWASHER, YOU MAY NEED TO DO IT 2 OR 3 TIMES
Jul 10, 2009 | Maytag 24 in. MDBH940AWS Built-in...
The Dishwasher is not cleaning the dishes
run a empty load, on the top rack place a coffee cup full of vinager. Run on hot or heavy duty cycle. Then try again with no more than 1/2 of the soap cup filled. If this works for you it was caused by to much soap
Jul 07, 2009 | GE Dishwashers
Dishwasher repair - Bosch
Can you remove the upper spray arm (is yours under the upper rack?)-mine unscrews and then you have to wiggle it off. Run faucet water into the arm; sometimes little bits of crud get stuck in the holes that spray the water out, and this prevents a complete rinse. I just had to clear these holes myself due to same problem (I might have a different machine, though). You can do the same for the lower arm.
Jan 25, 2009 | Dishwashers
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
173 people viewed this question
Top Viking Dishwashers Experts
Mike
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
