Question about Konica Minolta PP9100 N Economical printing for business PagePro 9100 N, laser up to 35 ppm 1200 x 1... Printer
NETWORK INSTALLATION PROBLEM
DEAR MADAM/SIR,
I AM UNABLE TO INSTALL THROUGH CROWN PORT+ ;BUT MY PROBLEM IS " IP " ADDRESS IS GOING ON CHANGING WHILE I ON PRINTER FOR PRINT.HELP OUT FORM THIS PROBLEM PLEASE.
THANKING YOURS,
Regards,
Zubair Khan Z.KHAN@TAIENGINEERS.COM
  • ZIMKHAN Apr 09, 2008
    GOOD TO HAVE PEOPLE LIKE U
    Sergeant:
  • 202 Answers
Hello ZIMKHAN
Please, correct me if I am wrong. Do you mean that you believe there is an IP conflict or IP assignment issue w/ your PP9100 N?
If the IP address of the printer keeps changing then it is most likely not remaining powered on all the time AND it is configured for "dynamic" IP assignment by your router (as opposed to a "static" (unchanging) IP address).
This can be remedied by assigning a static IP address to your printer (or the print server device it is connected to). This is usually done at the control panel of your printer or through the print server device software.
If you are not in a Domain or "larger network", the IP address of the printer or print server device should be w/in the same subnet as the rest of the nodes on your LAN.
I have a few questions for you:
(01) Is your printer connected to a "print server" or are you using its on-board Ethernet port?
This printer model is "network ready". That is what the "N" stands for in the printer model number. I would like to make sure that you are using the printer's Ethernet connection and not a print server device.
(02) Is the "Crown Port+" you referred to your router?
(03) Please, provide the manufacturer and model number of your router.
(04) Please, provide the manufacturer and model number of the "Crown Port+" device you referred to (if it is different than your router).
(05) If you are not using the printer's Ethernet port but are using a print server device instead, please, provide us w/ the manufacturer and model number of that device.
Please, click on THIS link. You will find the documentation that is available for this printer on this web site.
Please, download the Installation Guide (document name: 9100g_e.pdf) and refer to page 52 for instructions on setting up your printer for networking in a "Windows" environment.
This, of course, is assuming that yours is a "Windows" networking environment. If it is not, please, let us know what operating systems are installed on the computers w/in your LAN.
* Please, post back w/ your answers and
* any other info. you can provide (the
* more details you can provide the better)
* and we will be happy to work with you
* to resolve your problem.
* Thank you
* BJ
Posted on Apr 09, 2008
  • B Joan Rapier
    B Joan Rapier Apr 09, 2008
    Thank you for the kind comment, ZIMKHAN. We are more than happy to help you.
    Just be sure to keep this problem open (don't assign any ratings for solutions or choose a "Best Solution" ) until your problem has been resolved.
    We will continue to work w/ you until it is. Once you assign solution ratings or choose a "Best Solution", the problem will be closed and we will not be able to continue to assist you.
    Thank you,
    BJ @:)
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello Zimkhan
    How did it go? Did the information and link I provided you w/ enable you to get your printer working on the network OK?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to work w/ you.
    If it is the case, would you kindly take just a moment to assign a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Tip
INSTALLING A NETWORK PRINTER These instructions generally apply to all network...
These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc.
This example is for a network HP Laserjet printer.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer’s network configuration accordingly.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
on Dec 06, 2009 | Computers & Internet
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Change ip address
You cannot change the ip address, if you are using static ip address.If it is dynamic ip address, you can change it easily by resetting the modem or switching it off and on.you can also use Proxy server or Hide ip address software to change the ip address.
To check the ip address before and after changing, Visit the site ip-details.com Here you can also search IP,domain host and it also includes city, country, global latitude & longitude coordinates etc.
Jan 02, 2013 | Motorola RFS4000 - switch - 6 ports...
Where is IP address for the MFC-7220 printer
Network printers do not have a set IP address, you need to configure the printer with an IP address that uses the same range of IP addresses as your network.
The IP configuration is normally done through the printer's Menu on the printer's buttons.
If your are using a network IP range 192.168.0.*** that your wireless router issues automatically then select a fixed IP address on your printer above the number of computers that is installed on your network. (ie if you have 10 computers the make the printer's fixed IP address say 192.168.0.30) so the wireless router cannot issue a conflicting IP address.
When you install the printer driver on each computer then go to the Printer Properties - Port tab - click Add Port - IP port and enter the printer's fixed IP address and printer name.
Do a test print to check if your computer connects to the network printer.
Oct 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
I am unable to install hp laserjet M2727 nf MFP in the network. i don't know how to install it on the network? please suggest me the steps .
Hi
This is very easy setup to install the network printer. first to set the your desire network IP address in your printer.follow the mention option enter the Ip address.
  1. Press the Menu button.
  2. Press the Down Arrow to find Configure Device .
  3. Choose Configure Device .
  4. Press the check mark button.
  5. Choose I/O .
  6. Press the check mark button.
  7. Press the EIO (1 or 2) Jetdirect Menu .
  8. Press the check mark button.
  9. Choose TCP/IP .
  10. Press the check mark button.
  11. Choose Configuration Method .
  12. Press the check mark button.
  13. Choose Manual .
  14. Press the check mark button.
  15. Select Manual Settings .
  16. Choose IP address .
  17. Press the check mark button.
  18. Enter IP address with keypad.
  19. Press the check mark button.
  20. Choose Subnet Mask .
  21. Press the check mark button.
  22. Enter Subnet Mask with keypad.
After assign the IP addres in printer. connect to your printer with router or switch. and insert you HP Installation CD in Rom,
Go to the Control Panel and select Printer and Faxes click the "Add Printer"the new Add printer wizard open click next and remove the check mark in " Automatic detect and install the Plug and Play printer" click next, then you get "Select the printer port screen" Click create New port and choose Standard TCP/IP and click next.
You will get another New windows " Standard TCP/IP Add Printer Port" click next and put the Printer IP Address click next and next, Finish.
Now the windows will appear " Add Printer Wizard" click the Have Disk " and choose the .Inf file for your Installation CD, and Click Finish.
Your printer will install and the test will come.
If my solution solve you problem then give me four thumb
Cheer
Jul 12, 2011 | HP Laserjet M2727nf Multifunction Printer
How do i chang the ip address on my cannon IRC3170? or set it to automatic so that my computer can find the printer on the network??
After complete installation of printer
1. Go to control panel-> Device and Printer
2. select printer which you want to set an ip address and right click and select printer properties
3. It will display on general, select port tab
4. select the printer
5. Click Add port
6. it will display a printer port
7. Double click the standard ip address
8. click next and change the ip address
9. finish
Mar 19, 2011 | Computers & Internet
Problem with Network and Wireless driver
Hello Ken,
It sounds as if the problem is with your wireless setup. If you go into your property setting for the wireless when you are "connected" to your router, make sure it is showing a Gateway IP address. If not, you get limited or local access only. You will need to get the gateway IP address from your ISP provider or if you know the IP address of the router (DHCP) you can get all the IP addresses to get you connected to the Internet.
Good Luck
C2Solutions
Jul 04, 2010 | Computers & Internet
I am on a network with a brand new HP 8500. I have searched for the printer and my laptop doesn't pick it up. What amI missing?
Have you checked that the IP range for the printer is on the same IP range for your network? you could always cold reset the printer which will reset the network card back to zero's. You attach it to the network and your server should issue an IP address via DHCP. You should be able to see it on the network then.If not, the jetdirect network card may be at fault.Has the printer got a Jetdirect network card installed?
Oct 15, 2009 | HP LaserJet 8500 Color Printer
Brand new Brother MFC-685CW won't print via wireless
First, I would recommend NOT trying to manually install this printer by using the add printer wizard in windows and selecting the the port and drivers to use. I would use the install cd to set this all up, it makes setting up this printer MUCH easier. If you are unable to use the install cd then get the IP address for the printer from your router admin page then with the printer "installed" go into the printer properties, go into the port, add a port, and instead of using a printer name just type the IP address for the printer in. Also for any networked printer make sure you don't have a firewall blocking it (this would include making sure that if the printer requires a port opened in the router that all requests for that port are routed to the IP address of the printer).
May 09, 2008 | Office Equipment & Supplies
Konica Minolta PP9100 N Economical printing for business PagePro 9100 N, laser up to 35 ppm 1200 x 1... Printer Logo
230 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
