Question about Kenmore Washing Machines
Trying to get back cover off to check water hose on Kenmore washe
I cannot get the back cover off my Kenmore washing machine, model #26422503, Series 80.
    President:
  • 1,430 Answers
Where is the filter located on the Kenmore Series Model 110 washing machine?
washing machines don't have filters, is your problem due to no water entering the washing machine? if so , remove the water hose and you will find screens in the end of the hoses, remove or replace these screens.
Sep 05, 2009 | Kenmore 22422 Top Load Washer
My kenmore series 80 washing machine won't drain water. We have checked the hose and that is clear, what should we check next?
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 25, 2009 | Kenmore Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
2. Water Pump
Jun 01, 2009 | Kenmore Washing Machines
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
No cold water going into tub, valve is open
make sure the hoses are not kinked and check the screens inside the valve inlet and make sure they are not clogged
May 25, 2009 | Kenmore Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Hi MPT,
Don't take the back panel off!!!
Watch this video to learn how to access the machine.
Generally on a Whirlpool built Kenmore like yours, the drain pump has failed and now it's leaking. The pump is right there in front, the big round white thing. It's connected to the motor by 2 clips. It'll be one of two types of pump... this one or this one <----notice the difference in hose connections?
It's easy to replace, just make sure that the machine is completely empty when you remove the hose or have a shop-vac handy when you do.
And don't forget to rate my solution as "FixYa", deal?
SG
Apr 17, 2009 | Kenmore Washing Machines
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
I have a kenmore model # 110.26934691 / 90 series
Check the warm and hot cycles. If they work then the pressure valve needs replaced. Disconnect the watert hose to machine and make sure water comes out. Back screens may be clogged also.
Jan 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
108 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
