Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
24v54 husqvarna: how to I increase max cutting height by a couple of inches?
  • fixya354 Jun 04, 2010
    thanks for the answer on Husq 24v56 about the cutting height. I has thought of shimming the axel about 2" which should not cause too much instability. What do you think.
    thanks
    Fixya@cfoh.net
  • 420 Answers
It's not do-able without major modifications that may compromise safety, if you need much longer grass or wish to brush hog like cutting of really tall weeds you need a different rig or a power sickle attachment. I'm sorry but it's just not a good idea to hike the deck like that.
Posted on Jun 04, 2010
  • Mike Squire Jun 04, 2010
    find taller tires or complete wheels with the same bore as you have now.
    Getting drop spindles may be difficult but with some rod stock, torch set and welder you can make them and then you will need to shim or bracket the transaxle farther from the frame box.
The cutting height adjustor pedal drops to low cut setting? Why?
the adjustment rod screws into a threaded receiver raise the tractor and screw the threaded screw back in then make the adjustment. Good luck
Feb 11, 2016 | Husqvarna Garden
Why is throttle stuck wide open?
Could be a couple of things. could be a return spring sticking on the carb, or the throttle cable has frayed and sticking on. I've added the breakdown manual for you.
http://www.mediafire.com/download/68zm589mejh8jnq
Dec 20, 2015 | Husqvarna-Target Husqvarna K760 14 Inch...
How to remove fuel tank on 48 inch husqvarna riding mower
pull the rear seat/fender assy... the floor boards ( where your feet sit ) have a couple of bolts, then the seat springs have a couple of bolts... a couple of handles might have to be removed...
Aug 26, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
My height is not increasing from last last 3 years my height 4 fit 7 inch how can i increase my height pls help me
It depends how old you are.
I am assuming you are 15 years or older. If you are, as a health professional i recommend you see an Endocrinologist as soon as possible. This could be for a few different reasons
1) Growth Hormone Deficiency or insensitivity
2) Thyroid Hormone Deficiency
3) Malnutrition
4) Short family stature
Do not delay this, as earlier treatment will result in better success depdning on what the cause for this is.
Good Luck! Hope this Helped!
May 02, 2011 | Health & Beauty
One question, im looking to buy a husqvarna k760 demo saw, i need to cut metal, such as truck and trailer frames. just need to cut them down to length so i can load and bring to scrap yard. i figure it...
The K760 black cutter blade is called a Cut-n-Break blade. The manufacturer states that it has an improved stable core to increase its performance. I have a friend who recycles scrap metal and uses the Mastercraft 5" dual cutter. It cuts through metal like butter without any kickback.
Hope this helps,
Handie Andie
Mar 26, 2011 | Husqvarna Garden
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
235 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
