Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
Ive recently bought a 1080i samsung tv and was wondering will is there any way to connect it to a hdmi cable so i can play my ps3 in better quality?.
IF YOU HAVE A DVI CONECTER A BIG WHITE PLUG WITH MANY CONNECTERS YOU CAN BUY A HDMI -DVI ADAPTER BESIDE THE DVI CONNECTER YOU WILL HAVE INDICATION FOR DVI AUDIO YOU MUST PASS TWO AUDIO CABLES FOR SOUND
Posted on Jun 03, 2010
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
I have a Playstation 3/blu ray player and I don't know how to get hi def video on a samsung hln467w
Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Separate video and sound on hdmi
yes it would be possible to separate audio and video from your PS3. You would need to go to the PS3 setting for audio and choose Optical instead of HDMI. You would need to connect and Optical cable from the PS3 to the receiver. Then on the receiver you would need to set the digital inut for your source(PS3) to optical.
Mar 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
You may want to try a good, Monster Cable, HDMI cable. Visit this page: http://www.monstercable.com/HDMI/advancedhdmi.asp
If you have a standard HDMI cable, it will not support 1080P.
So this is one of the few times that I will recommend spending the money for a better cable.
The better cable improves picture color quality, from 8 bit to 12 bit and it improves audio quality.
Dec 24, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Hdmi settings?
Hey Kris, this might all be about different 1080 settings. Maybe Your consoles work on 1080i and the TV is 1080p.
It more sounds like your receiver has a faulty HDMI jumper, which you wont be able to fix. Here`s what i would do:
If your lcd has two HDMI inputs, use on for each the receiver and the other for the ps3...
2-For how important is to rather connect the ps3 via HDMI, for picture quality. then simply get an HDMI splitter, yes... YOull have to go and switch from receiver to ps3 whenever you want to play BUT it really sims your receiver is not going to cut it.
The pink you see is an incorrect "GAMMA" signal thats only induced by a malfunctioning software or hardware.
Is your receiver from a cable company? Try to get it replaced.
I would start there and if it wont make a difference, go with the splitter. YOu might get one at walmart, Radio Shack or ebay.
Hope it works and please feedback with results.
Good luck!!!
Jean
Dec 05, 2007 | Yamaha HTR-5990 Receiver
Samsung LCD tv and PS3
the problem is with the frames per second that the ps3 is putting out. i wound up calling both samsung and sony and the problem was in the settings. the ps3 allows you the option of playing in 24hz and for some reason if the option isn't turned off our tvs won't display frames at that rate. just go to the dvd settings and deselect the 24hz option, changing it from AUTO to OFF... the only problem i have with this is that this should effect the picture quality, becasue if it isn't displaying in 24hz that means it is downscaling the display and if it isn't upscaled by the tv's processor, then the display should be worse. i might be imagining it, but it does seem worse.. atleast they play now though. hope i helped.
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
228 people viewed this question
Henry  Thomas
Henry Thomas
