Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer fills up with water, but nothing after that. Lid is closed so should work. I checked all cycles.
    President:
  • 1,430 Answers
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at http://appliancehelponline.com/toplidswitchvideo.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Jun 03, 2010
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washes but dosen't drain
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
Jan 03, 2009 | Estate TAWS800JQ Top Load Washer
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Won't run
Most washers today will not do anything after fill unless it sees the lid switch (innerlock system) closed. The same as having the lid of the washer up during a wash cycle. They will fill but until the timer, or ECB gets a signal back from the pressure switch (water level switch) it will go no further. Some of the electronic machines will also time out in the fill cycle because of a lack of water flow. The fill cycle is a timed event and if the water level switch ( controlled by the ECB ) does not close in the time alloted, it will stall. This can be checked by hitting the start button again. Most of these problems are caused by a lack of water flow on the initial start up. Cleaning your water inlet screens in the supply hoses and screens in the mixing valve itself will solve this issue.More information to the specific model would help pin-point this problem.
Sep 19, 2008 | Maytag LSE7806A Top Load Stacked...
Washer won't start water fill/ the dryer works fine
I'm Neil, Glad to be of assistance for you!
Sounds like an Electronic problem.
You should call service.
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
Aug 24, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore washer
Check the lid switch first, make sure when you close the lid the switch is activated with the tab on the lid, if the switch doesnt work, your machine will only fill and wait for the lid switch to be satisified. You should hear the lid switch lick or snap when you open and close the lid.
Start here, if could be the motor or timer, however check lid switch first.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Washer will not work after filling it with water
Shawnie, sounds like your lid switch is giving you problems. They revised the switch, it comes in a kit with instructions. Part number 12001908. Take a small screw driver with the lid closed and push in on the actuator to verify that this is the problem. Catriver..post back.
Jan 25, 2007 | Maytag LAT3600A Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
369 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
