Question about Olympus Stylus 840 Digital Camera
Keep getting clean the contact area of the card message, even after cleaning card...need to use camera...what to do?
  • 3,083 Answers
The camera is not reading the card correctly, so it's giving that message. The fingers of the card and the contacts of the card inside the camera need to be cleaned, as a first step. You can use a qtip and alcohol to clean the fingers inside the camera- do not bend them or use a lot of force, but try get them as clean as you can. Hopefully, this will work. If it doesn't, there is a chance that the card is bad. Try another one that has worked, if you have one, then you will know if the card's bad or not. Other than trying those steps, service will be required. Make sure you get an estimate first, since the cost of repair can often exceed replacement value. Good luck, and hope the cleaning fixes the problem.
Posted on Jun 03, 2010
Adapter card for olypmus fe 4000
my memory card say it is locked, can u tell me how to unlock it
Jul 02, 2013 | Olympus FE-4000 Digital Camera
When turning my camera on the message clean contact card appear. How do I access and clean the card and what to they mean by contact card
Hi there, this is most likely the memory card. You need to clean the little metal contacts on the card with an alcohol wipe or a soft lint free cloth. The problem is likely that the camera cannot properly read the card - cleaning the contacts should fix this for you.
Hope this helps!
Tom
Jul 22, 2011 | Olympus FE-340 Digital Camera
How to remove card error in fujifilm jz300 camera
Welcome to FixYa.
The reasons why do you get a message "CARD ERROR" are:
1. The memory card is not formatted.
2. The memory card requires cleaning or memory card is damaged
3. Incompatible memory card.
4. Camera malfunction.
What do you need to do are:
1. Format the memory card.
2. Clean the contacts with soft and dry cloth. If the message is repeated, format the memory card again. If the message persists, replace the memory card.
3. Use compatible memory card.
4. Contact FujiFilm dealer.
Feel free to send us your comments and suggestion fi this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | FUJIFILM FinePix JZ300 Digital Camera
Memory card shows error
It is possible that you have a faulty card. Sometimes if you very carefully wipe the contact area on the card with a rag soaked with little isopropyl alcohol, it will clean off oils that can get on their from your hands and make contact again. You can also try taking a CLEAN pencil eraser and GENTLY cleaning the same area if the wipe doesn't work. If it still doesn't work, see if you can find a friend with a similar camera or a card reader to try the card in, before you go buying another card. It could still be the camera.
Feb 19, 2011 | Canon PowerShot S3 IS Digital Camera
I get a "no memory card" message on my Canon
Clean the contacts of the memory card with a pencil eraser - it might be dirty and not making a connection inside the camera.
Dec 14, 2010 | Canon Powershot A2000 IS Digital Camera
When i turn camera on it says clean the contact area of the card
There is a possibility of, your card is may be corrupted or virus infected..... Try by formatting the card and scan through good antivirus..... If problem persist then, Sorry you have to replace the card.....
May 01, 2010 | Olympus FE 45 gold Digital Camera
I've cleaned and even bought a new card after the camera insisted i clean the card and it still continues to make that instruction even on the newly purchased card
that camera uses an XD card ... its kinda hard to do but look inside the camera card slot (a single LED flashlight can help) and see if there is a bent contact .. look for contamination like a sliver of paper or a hair that might be keeping a contact from connecting to the card .. if your camera is in warranty then that should be covered ..
Oct 16, 2009 | Olympus ? 1030SW Digital Camera
XD card setup
Try to clean contacts with 70% alcohol and q-tip.
Mar 29, 2009 | Olympus FE-210 Digital Camera
Card problem
Hey abbytho,
The most common reason for this message is the memory card or the internal memory is not formatted. If you don't know how to do this the directions should be on page 75 of your manual. If this doesn't work try cleaning the contact area on your xD card with a soft dry cloth, and if this doesn't work you should have the camera looked at by an authorized service technician. I have provided a link to your camera manual below.
http://www.fujifilm.com/products/digital_cameras/a/finepix_a500/images/a500_e_manual.pdf
Sincerely,
Allan
Go Ahead. Use Us.
May 09, 2008 | Fuji FinePix A500 Digital Camera
Olympus Stylus 840 Digital Camera Logo
79 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
