Question about Western Digital 160GB MyBook Essential Edition 160 GB USB 2.0 Hard Drive
Unresponsive The drive is unresponsive. Green light is constantly lit, however, it is not being recognized or found on my computer and I cannot access my files.
    Guru:
  • 592 Answers
Have you placed the usb cable into another port, if not do so and see if this works.
another thign is to try a new USB cable to see if there is an issue with it. Check the rear of the unit to make sure the usb mini port is not damaged.
When reconnecting it to the computer does the computer recognize the drive and installs it? if so and there is no drive letter, you can right click my computer/computer and click manage. from there you can use the disk managment to set a drive letter. From here you can also check to see if there is a conflict in device manager.
Posted on Jun 03, 2010
Unresponsive
This sounds like an ink pad warning.
Try resetting this.
Dec 12, 2013 | Canon PIXMA MP180 All-In-One InkJet...
The green light on the MY BOOK ESSENTIAL is continuously flashing but computer does not recognize it. It can't be found anywhere.
If you are using a Windows Operating System that is more current than ME, 2000, or XP, this device is plug and play and will require no drivers. You should simply be able to find it by clicking the start menu in the bottom left hand corner, clicking My Computer, and it should be listed with your other Hard Drives and Devices with removable media It will NOT be drive C:, this is your computers primary Hard Drive. Once you find it, you will then only have to double click it to access it.
If you are using Windows 98, you will want to download the driver found on this page.
http://support.wdc.com/product/download.asp?groupid=101&sid=38&lang=en
Any upgraded Linux or Mac Operating system should also recognize this as a plug and play device, and should require no drivers.
Jul 29, 2011 | Western Digital My Book Essential Edition...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Drive not recognized
Have a look at this Website>
http://support.wdc.com/product/install.asp?level1=2&lang=en
May 07, 2009 | Western Digital 80GB Passport 2.5" USB...
DVD and CD drives not working
Drive may need a firmware update. If you have internet access then go to drive's manufacturer, and check for an update. There could also be a drive configuration problem, need to see if drives are recognized, by the system.You can right click my computer select explore and look for drives or go to settings, control panel right click system, open, then hardware, device manager. Then look for cd and dvd drives. If you see yellow exclamation marks or question marks then updates drivers. This is a start, try to see if the drives recognized.
Dec 16, 2008 | Compaq Presario 5000 PC Desktop
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
Red light, "spinning, dropping noise"
There are some freeware that can recover data from problematic disks (like yours), formatted disks, repartitioned disks etc. since you said that the disk is recognized by the computer. You can try Disk Doctor NTFS, Recover My Files, etc. You may not be able to get all the files (depending on the problem of the disk which seems to be a spindle and platter problem), but at least you would be able to recover some.
I recovered a server recently just using one of these softwares.
Jan 14, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Light turns on but My Computer does not recognize the drive
The problem is just with EXTERNAL.
Hdd is fine...Just change the external or buy new
Nov 18, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Western Digital 160GB MyBook Essential Edition 160 GB USB 2.0 Hard Drive Logo
73 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
