Question about Heath Zenith 270 Degree Replacement Motion Sensor - White, SL-5716-WH
I have a Heath/Zenith SL-5716 motion sensor light in my backyard, that isn't working anymore. I have to either leave it on all the time or off. I think the switch/settings have been changed and I don't know what settings I should use to get it working properly again. Thanks.
  • Karen Cox Jun 03, 2010
    This was my first experience with FixYa and it was most rewarding. Thanks!!
  • 505 Answers
Here is a link to the manual
http://heath-zenith.hcents.com/data/manuals/598-1307-01.pdf
Try setting the switches according to the manual
If problems continue, I imagine the light sensor may be bad, you can replace the whole unit for not too much money.
Posted on Jun 03, 2010
Defiant 270 Degree White Replacement Motion Sensor manual
i ave a live switch leg no switch wil sensor function correctly or will it always stay on?
Oct 17, 2013 | Heath Zenith 270 Degree Replacement Motion...
Light does not shut off
I have had a lot of problems with this model of sensor. I bought 6 a few months ago and they all are bad. I have since switch to a different model sl-5315-wh-a and all seems good again. I got them from Lowes. I think that they were around $23 each. I have been using these type sensors on my house for 20 years and have replaced them all at least 2 times.
Hope this helps
Feb 03, 2011 | Heath Zenith 270 Degree Replacement Motion...
The lights stay on. Never had it do this before. have turned off the switch and reset to 1 min vs 5 min, and it still stays on. any suggestions?
Here goes......First of all I Have the wireless model sensor.....I called heath and they replaced the sensor......Still did not work...Like you the flood lite stays on......I called them again and they said it could be the floodlite base. they told me to to send it back to the warrantee dept which I just did today.....
Feb 01, 2011 | Heath Zenith 270 Degree Replacement Motion...
I replaced the batteries in the motion sensor and now it appears that I need to learn how to adjust the timing. Is there a manual for the 270 (I think this is the one from the picture)?
there is a slide switch on the bottom of the sensor......test....1 min.....5min...
u may have to reset the sensor....turn power off .....then remove batteries.....wait 5 min....then turn on power....then replace batteries ......do not move the sensor and wait 1.5 minutes...
U can also call heath zenith @ 800 858-8501 and talk to tech support....
Jan 24, 2011 | Heath Zenith 270 Degree Replacement Motion...
When i flip the switch on the light stays all night it doesnt turn off it was working fine i dont know what happen an i lost manual so can u please help me
Clean the light motion sesor plate under the light bulb.It dirty and it cover with dirts and moister probally that,why it on all the times.
Oct 16, 2010 | Heath Zenith 270 Degree Replacement Motion...
My sensor no longer works. It use to turn on the porch light when someone entered the carporch. How do I open the sensor so that I can put new batteries in it? I know that it uses AAA batteries.
Manual for this sensor is not available.
In the Zenith I have installed The motion sensor battery slot was h at the back side of the sensor, you had to remove the sensor from the wall sliding it on one side to access the battery. It mounted two AA batteries, not AAA.
Aug 17, 2010 | Heath Zenith 270 Degree Replacement Motion...
I have a sensor that stays on all night when the
Your motion detector is based on infrared or heat sensing technology. Moving air or wind will make your unit more sensitive to false alarming. Here are a few things for you to check: 1) make sure your unit is sealed. Any holes or openings in the unit's casing will affect operation. 2) you may need to readjust the unit's sensitivity. There may be an adjustment pod or jumper inside the detector to reduce sensitivity. 3) make sure the unit is mounted securely. If the wind causes the detector to move, even slightly, this could be the cause of your problem.
Jan 19, 2010 | Heath Zenith 270 Degree Replacement Motion...
Motion sensing seems to be funky as the weather gets colder. I have the sensitivity turned all the way down and the lights still come on when nothing is there. They fade to dark (or dim if that's what I...
Put a cover (shoe box, piece of cardboard, etc.) over the eye to block any possible movement that it may be seeing. If it still acts the same, then the electronics have failed. If it doesn't, then the eye is seeing something that you are not.
Let me know what you find.
Dec 16, 2009 | Heath Zenith 270 Degree Replacement Motion...
Heath Zenith 270 Degree Replacement Motion Sensor - White, SL-5716-WH Logo
678 people viewed this question
Top Heath Zenith Home Security Experts
Mike
Domenico Grillo
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
