Question about Panasonic SC-HT930 System
Panasonic SC-HT650 When I turn my receiver on F61 pops up on the receiver diplay then shuts itself off. How can I fix this? Is there a way to reset the receiver? F 61
  • 4,234 Answers
This indicates protect mode. One of the output amp pacs needs to be replaced. It is either part number: STK470-050 ($16) or RSN311W64D ($95)
Dan
Posted on Apr 09, 2008
2 Suggested Answers
SOURCE: Panasonic SC-HT650
from what i heard this is a common problem with this unit (mine included). apparently it cost more to fix than buying a new one.
Posted on Mar 08, 2007
F61 error message panasonic sa ak410
try cleaning out the fan and make sure it spins freely. If the unit detects that the fan isn't spinning it will shut off.
Oct 07, 2013 | Audio Players & Recorders
I have a Panasonic SA-AK240 C.D unit, when I switch it on F 61 appears then it shuts itself off, please can you give me some guidence, as I have miss placed the manual
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 06, 2011 | Panasonic Audio Players & Recorders
When i turn on my receiver f61 code comes on then it shuts off how do i fix it. Panasonic SC-ht650
Many things can cause the error code f61 on a Panasonic.
Most of them need a service tech to repair. Output IC or voltage regulator....
The one thing you may be able to check is the cooling fan, it should turn on hen the power button is pushed. Make sure it spins freely.
Most often it is the output IC
Feb 11, 2011 | Panasonic Audio Players & Recorders
Panasonic sa-ak630. i turn it on an display said f 61 an turns back off all in a matter of a second or two... wires are all good.. and even just left everything unhooked an still no help... manual said...
F61 is the shorthand for Panasonic machines to mean protect mode. See the link below for a generic explanation of protector. Specifically, in your machine, either the regulator IC has failed or the output amp IC has failed. In any case, the repair will not be cheap. The output IC costs between $75-$125 depending upon the specific IC.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Sep 06, 2010 | Panasonic SA-HE100 Receiver
F61? how do i fix it...................everytime i turn my panasonic sc-ak340 on i get a error code that reads f61 and then my system shuts down by itself..can this be fixed?
I've encountered that kind of problem.
f61 appear on the screen then shuts down the unit.
The very common defect is your fan, output ic (rsn series).
First check the fan if it is in good condition (disassembling the component is quite technical it need a lot of care).
sometimes the fan is full of dirt that's why it will not work properly which the system sense and uttered the unit to switch of avoid further damaged.
If you confirm that the fan is working properly I will suggest you to bring your unit to a qualified technician/service center because replacing the output i.c. is more technical.
Dec 13, 2009 | Panasonic SC-AK340 Shelf System
F 61 Code
The if the "bad sound" is coming from the speaker(s) it probably needs the output ic. If it is coming from the player itself check that the fans are working. F61 is an amp error code but a non-rotating or unplugged fan will also set it off.
Feb 09, 2009 | Panasonic SC-HT920 System
F61 error
If memory serves me correctly, the F61 message is teh shorthand for protect mode. There is a problem with the output section that is being detected. The unit shuts down to prevent additional damage to either the amp section or the speakers. I'll look up your specific model for more details. In the meantime, check the speaker wires to be sure that they are not frayed and crossed.
Dan
Apr 08, 2008 | Audio Players & Recorders
Turns off
My system does the same thing with F61 displaying for 5 seconds before shutting off. I took the fan in the rear off, and noticed that it came on to the touch but didnt stay on continuously. However, when it came on It started performing normally. So, I also noticed that the insides where the fan was located became warm when no air was blowing on it. System will shut off to protect itself. Dont know how to get fan off yet. But fan for my model is sold on Panosonic Website. Not very expensive if you know how to install. Around $17.00 for fan itself. If someone knows how to install , please send message.
Dec 22, 2007 | Panasonic SC-HT70 System
My stereo turns off by itself and the indication F61 appears
1st case dry solder connection in power board and amp bpard ,resolder and unit will be working o.k
Oct 28, 2007 | Technics SC-EH780 CD Shelf System
Panasonic SC-HT650
Feb 05, 2007 | Panasonic SC-HT650 System
Panasonic SC-HT930 System Logo
219 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
