Question about Directed D800 Car Audio Amplifier
Amp cuts out when turned up
I've had this amp for a few months, and it ran my two kicker CVR 12's just fine, i could crank it loud and they would sound good, amp would never overheat. but this past weekend, it starts cutting out when it gains volume or the bass hits, and the led goes from green and blends to an orange and red then cuts out for a few seconds, sometimes doesn't put out at all. The wiring is fine, it just cuts out for no reason.
    Problem Solver:
  • 5 Answers
That amp cutting out like that means that its probably shot and it time to start looking for a new one
Posted on Apr 10, 2008
I have a kicker sx650 powering two kicker cvr 102 at 2ohms but i havve no clue on where to set the settings at and i know this amp should make these subs pound. i need to know exactly what to put each...
How I tune:
turn amp all way down or disconnect rcas for now, turn up stereo to a song with some bass you listen to and crank it as loud as you would (not max about 3/4, use this to tune inside speakers (don't have bass maxed/distortion...)). Now dial in amp: turn up a bit probably to 1/4 or so then tune frequency I'd usually say around 100hz, then adjust gain again to where it sounds good...be easy on them for awhile to let them break in (don't blast them all day!). Usually bass boost is only 1 frequency with a curve (40hz or something)...so I try to not use it much....
Apr 25, 2014 | Kicker Car Audio & Video
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
How do i wire a single 12" kicker cvr dual 2 ohm
Simple power fom amo to power on sub. Ground on amp to ground on sub
Feb 28, 2013 | Car Audio & Video
My dual 2 ohm cvr12 kicker are burning on the red dot Connection what can it be and also the symtem hits fine for min then fade.
check that you have the correct impeedance polarity try turning down your amp gain most of the time its wattage match get as close of a match as possable ohms must be corect for amps specs
Nov 17, 2012 | Kicker Comp CVR 12 x 12 Car Subwoofer
What's the best way to wire a 12 inch kicker CVR
Ok, first you need to have at least ten gauge wire cause the amp needs agility of juice. Next you want to find a good ground to frame of the car (if its wrong you'll hear road noise through speaker.) Next look on the fire wall and find the terminal that has other wire coming to it (one from positive to the amplifier on battery the rest out top other you want to put an inline fuse to amp.and have ground write other side of the cart than the power. run write to amp then to your speaker I believe I made it is simple for you as possible good luck
Dec 07, 2011 | Kicker Car Audio & Video
I have 2 12 in kicker cvr tryna drop to lower ohm
http://www.colomar.com/Shavano/dvc_spkr_wiring.html
Use the above site for several wiring schematics on dual voice coil speaker hookups. It will show how to wire for different impedance.
Also, I think the CVR 12's come in 2 ohm and 4 ohm impedance. See if you can check yours to determine which you have....
Jun 28, 2009 | Kicker CVR12 Car Subwoofer
Why does My AMp turn off
  You need to use 4 guage or larger wiring with this amp. Also you need to make sure the power wire and ground wire are the same guage.(thickness)
   The ground wire needs to be as short as possible from the amp to the metal of the car.
  Make sure you are using a 14 guage or larger speaker wire form the amp to the speakers.
Jan 15, 2009 | Jl Audio 250/1 Car Audio Amplifier
Hook up
how do you wire up a kicker cvr 12
Jun 14, 2008 | Kicker CVR12 Car Subwoofer
Amp cuts out at certain volume
is the output signal distorted? if not one of the subs could be damaged subs are capable of playing even when damage ,try them 1 at a time to see what happens.
May 17, 2007 | Kicker 04KX350.2 Car Audio Amplifier
Directed D800 Car Audio Amplifier Logo
443 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
