Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
My gps works up to the point that it cannot locate satellites. It asks if I have travelled 100 miles or more and whenI hit no, it goes back to searching for satellites with no luck. Is that a fixable problem?
    Problem Solver:
  • 7 Answers
Try answering yes. If the original location has been lost due to battery replacement etc, These devices go to a home location which may be anywhere to begin looking for the satelites. It could take 30 minutes or more to locate itself. Just turn it on and let it look for a long time.
Posted on Jun 03, 2010
I cannot reset the home location. It is now Massachusetts it keeps Illinois as the starting location. What do I Do?
The GPS knows where it is as long as you have locked satellites, if you have traveled over a considerable distance the GPS may need some time to find the constellation so it can provide location. The GPS may take up to 20-30 minutes to lock satellites after traveling, so you may have to leave the GPS in a stationary position powered on for around that long.
Hope this helps!
Apr 12, 2011 | Garmin nuvi 205W GPS Receiver
I have a 2008 Dodge Ram with Sirous Satelitte built into the radio. It's locked up and will only show channel 184 and not play anything. I disconnected the battery and that did't correct anything. Any...
I have the exact same issue on my 08 Ram 1500. It even shows the same channel 184. Of course, it's warranty just expired at 39000 miles. I took it to the dealer anyway, and to quote the service tech "it points to the satellite module". Key word is points. A new module (the receiver) is $313 plus the $79 labor fee. WhenI asked if the new module did not fix the problem, if I would get a refund on the $313, he just kind of looked at me and eventually said no. I am looking for other solutions....
Oct 18, 2010 | Sirius Satellite Radio Receiver
My Garminis taking a really long time to acquire satellites( sometimes 5-10 min),especially when I flip the top up to turn it on and whenI flip the top down to turn it off ,it acquires the satellites...
are you inside when trying this ? Garmin has a very bad reputation in acquiring satelites when in coverered position.
Go outside and you will notice it goes much faster.
Aug 11, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Trouble locating satellites
Hi, my name is Vince & i had that very same problem with my nuvi 200w, have you tried to update it on your pc ?, i updated mine after travelling down the motorway at 40 miles an hour thinking that their was road works after the sat nav told me. I also found that updating it seemed to increase the signal strength too, try it, it may solve your problem.
Apr 24, 2009 | Garmin nuvi 260W GPS Receiver
My Garmin Nuvi 360 lost satellites during use and can't locate
I had the same problem with mine...I shut it down and left it off while giving it a full charge...
Jan 14, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Battery replacement now ca't find satellite Garmin c320
I had the same issue with the only difference that I haven't replaced the battery yet. When my unit can't locate or acquire satellites I change between GPS and WAAS mode. Within 45 seconds my unit successfully locates satellite. After some time if I disconnect unit I might have to switch it back to GPS and so on, and so on, and so on. It worked for me for past 3 months... Hope it will help you...
Nov 12, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Takes a long time to get signal
Hello annmarie2875,
In order for your GPS to calculate its own location, it needs to receive data reports from four or more GPS satellites. This process is normally pretty fast and will typically take approximately two minutes. However, this assumes that the GPS is used outdoors and has a clear view of the sky.
Obstructions such as tall buildings, trees and local terrain such as mountains and hills can affect your receiver's ability to "see" the sky. If you are using the GPS inside of a vehicle without an external antenna the GPS may also have a hard time acquiring satellites depending on where it is mounted. Ideally you want the GPS to be installed in the lowest possible point inside of the vehicle that has a clear view of the windshield and side windows.
A GPS receiver without a clear view of the sky can take a long time to get a fix on its own location. Additionally, the process can also take additional time if the GPS has been powered off for an extended period of time or if you have traveled a long distance (greater then 500 miles) since it was last turned on.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 10, 2008 | GPS
Can't find satellites
Hello Ray_of_Hope,
In order to get a "fix" on it's current location your GPS needs to download data from three or four GPS satellites. Typically, this should happen in about two minutes or less from the time you first power on the unit. This can take a little bit longer if its been a while since you used the GPS or if you have travelled a long way since you last turned the unit on. Your Garmin Nuvi 200W should be acquiring satellites and providing a location report pretty quickly after power up.
Once thing that can affect the performance is whether not not the GPS has a clear view of the sky. If you are operating indoors, in a car, or anywhere that has a lot of obstructions (in a city with tall buildings or a forested area with a lot of trees) these things can block your GPS's view of the sky and prevent it from receiving data from one or more satellites. This can cause the GPS to be unable to provide a lock on its current location or to take a very long time in locking on.
Best Regards,
Ken
"Go Ahead. Use Us."
May 29, 2008 | Garmin nuvi 200W GPS
GPS Logo
74 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
