Question about Nikon Coolpix L22BLUE Digital Camera
I have purchaced nikonL22 on 10th May,I observed that some times photos are comes in voilet colour & photos are having full of horizontal lines,what may be the reason and what I have to do? If neccessary can I send such photos?
    Guru:
  • 1,705 Answers
It shouldn't do that, as its new I'd suggest you take it back to the dealer/vendor, request they demonstrate to your satisfaction. If they can't request a replacement or refund under warranty.
Posted on Jun 03, 2010
During use often screen turn voilet white colour then after hitting the monitore some time it turn back tell me what is the problem
It may be related to DRY-Solder of the components on Main board of the CRT. So please call local monitor repairer and make it to solder the components properly without drysolder.
Jun 04, 2011 | Philips Magnavox 107E 17" CRT Monitor
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
I have an epson DX4050. I currently have a full blank ink cartridge but have one empty colour catridge and 2 other colour catridges which are running low. I want to photocopy a peice of document in black...
First, using B & W to copy a photo will cause large black blotches.
B & W are actually made up of shades of Black. To get the best quality for a B & W photo, switch to "Grayscale"
Next, is the black cartridge full? Are you using any type of refilled (absolutely worst possible choice) or a third party cartridge (second worst possible choice).
Feb 27, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Photo 870 only prints black and white
WHen your p;;rinter name comes up, check the printing p;references. You have "P:rint colors as black & white" checked. Un check it. It is in the printer dialog box, not PSP.
Sep 15, 2009 | Epson Stylus Photo 870 InkJet Printer
Print alignment failed / have tried to rectify several times
It seems like it may be a hardware problem, but the best bet for you would be to reinstall the printer drivers. It should fix it,
Jul 27, 2009 | HP Photosmart C7180 All-In-One InkJet...
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
I have a JVC KD-G441, which I have just put in the car. However, the preferred settings do not get saved if I turn off the engine. Does anyone know why? The car is a Peugeot 206 SW, if that helps. Jade
For all car cd players their is connector back side of the cd. having bunch of wires, in that if you connect squencily , the colour code of the wires are as follows
1. black for earth
2. red for acc, that you have to connect through ignition key +12volts
3. yellow, +B for continous supply that is battery
4. white and white with black stripp for front speskers
5. greay , greay black for front speaker
6. voilet ,voilet black for rear speaker
7. green, green black for rear speaker.
8 blue, for system remote .
if your yellow wire of +b is wrogly connected then memory problems comes
please try
regards
sam
Jul 12, 2008 | JVC Car Audio & Video
Epson Photo R265 Lines every 2.5 cm
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
cx3200@tiscali.co.uk
Dec 17, 2007 | Epson Stylus R265 InkJet Photo Printer
Green Patches and Horizontal Line
its your ccd chip,, its broken,, u can let them repair it but its cheaper to buy a new one,, your ccd chip does not show the manufactor on your screen but it controls the colours of your photo, so u only can see this when u took the picture,, and for some reason the video does not need the ccd chip,, the ccd chip is only for the photos u gonna take,, hope i helped ya
Oct 01, 2007 | HP Photosmart R707 Digital Camera
Colour printing
If the test patterns are not matching what your printer tells you is normal and your photos are banded horizontally, you may have clogged nozzles and printhead. Do a maintenace clean under your printers direction, and see if it now prints ok. Also, you may be low or out of one particular colour, but still have enough of the others and the printer will try to compensate by using available colours, hence colour banding and distortion. A manual clean with cotton buds and cleansing solution is recommended if the first clean does not help.
Dec 12, 2006 | Canon BubbleJet i560 InkJet Printer
Nikon Coolpix L22BLUE Digital Camera Logo
100 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
