Question about Olympus Cameras
Size of uv lens filter
What size of uv lens filter do i need to buy for my camera.
  • 169 Answers
Can you give me details of what kind of lens you have, Brand/Model with the F-stop size. Tony
Posted on Jun 04, 2010
I have just purchased polaroid lense filters polaroid say they are compatible with Nikon d90 but I cant get them on do I need something else to attach them
Filters must be the right size for each lens. For example the 18-105mm kit lens that comes with most D-90 kits uses a 67mm filter. They thread into the main lens. It is always safer to put a clear or UV filter on your camera lens to protect the expensive lens glass. You can thread another type of lens onto it as easily as you can your base lens. Be sure and do not force a threaded lens filter onto your lens or you will damage the expensive lens. It should thread on easily and do not over tighten it.
Dec 12, 2014 | Nikon DSLR D90 Digital Camera
Will the Quantaray 49mm to 55mm step up ring work on a Sony a100 DSLR camera
The step-up ring will on any lens with a 49mm filter thread, regardless of the manufacturer. The easiest way to find out whether it works with any given lens is to see whether the ring fits onto the front of the lens (you could also read the filter size written on the lens itself).
If it doesn't fit, purchase the appropriate step-up ring. That will be much cheaper than buying a whole new set of filters.
If the new lens(es) have a 55mm filter thread then you don't need the step-up ring at all. The filters will mount directly onto the lens.
Mar 17, 2013 | Cameras
Dear sirs; What type of uv filter fits a quantarary tech 10 28mm - 200mm zoom lens. I have several 62mm filters and the zoom lens does not accept the normal threaded screw on format common to lenses
First, make sure that the lens diameter is 62mm. It should say on the front or on the body of the lens. If this is correct, it could be a unique mount that would require a specific brand. If it's quantaray, it might require quantaray filters. If it's an old lens, it might require an attachment to the front of the lens that would act as a filter holder for the square filter tiles.
Jun 04, 2012 | Cameras
I bought a Rocketfish 55mm uv filter and tried to install in on my 18-55mm lens. I thought it would be easy but I think it's a wrong fit. I need help installing it.
The 55mm uv filter refers to the diameter - 55mm. This is unrelated to the focal length of your lens 18 - 55mm, which could be any diameter. You need to note the required filter size of your lens and purchase the appropriate size.
Jan 24, 2011 | Cameras
How do I fit the Hoya UV filter that I have been sold with my New Nikon D3100?? Darent be too heavy handed as new to this. Thanks.
The filter doesn't go onto the camera, but onto the lens. Assuming it's the proper size, it should just screw into the threads on the front of the lens (the end away from the camera). If the lens hood is on, remove it first.
Nov 07, 2010 | Nikon Cameras
What size uv filter do i need for an olympus sp-570uz camera ?
The SP-570UZ does not have a filter thread; therefore, lens filters cannot be attached directly to the camera.
Filters with 55mm diameter can be attached to the SP-570UZ via the CLA-10 Lens Tube Adapter, sold separately. However, it is not recommended because vignetting may occur in the corners of the image when the camera is set to wide angle positions.
The CLA-10 Lens Tube Adapter (Item #202104) is available from authorized Olympus dealers and also online from The Olympus Store: http://emporium.olympus.com
Apr 26, 2010 | Olympus SP-570UZ Digital Camera
My Nikon D40 18-55mm lens won't work on automatic
THERE is a problem in lens not with the UV filter
remove the lens clean the contact of lens & camera if not working repair or replace it
Jul 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon coolpix 4500 uv lens
I bought a 4 lens kit - I think from Amazon. It was a long time ago.
The size is 28mm.
yes, here it is
http://www.amazon.com/Nikon-28mm-Filter-Set-Coolpix/dp/B0000521B9
Oct 14, 2008 | Nikon Coolpix 4500 Digital Camera
Filters
If it is the EF-S 18-55 mm lens, the filter diameter is 58 mm.
Apr 18, 2008 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Lens Protection Size!!!
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Cameras Logo
76 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
