Question about LaCie (300770) 250 GB Hard Drive
No longer recognised by laptop
I appear to be having other problems with my SAMSUNG R60 laptop but my Lacie external hard drive has stopped being recognised by it and makes a constant 'beeping' sound when connected. The same happens when I link it to my wife's HP laptop.
Any ideas?
  • George Bill
    George Bill Jun 03, 2010
    These drives are notorious for having problems, are you able to at least see the drive in properties if you right click on your desktop system icon?
  • harrisona Jun 04, 2010
    Gymowner; no - not even in 'My Computer', which is odd.
  • 185 Answers
That is a common noise when your HD just failed it can be internal or external drive most of them work the same way, there is 2 metal readers that hover on top of the actual disks to read the information. Those readers get stuck (beeping noise) or keep going back and forward trying to read (that is the clicking noise) a way to try to fix the problem (it works sometimes) is replacing the circuit board attached to the hard drive (inside the metal enclosure) and you have to find one with the same characteristics as the one you have now. sometimes when we really need to recover the information we try that and it may, may not work
if it works for you, don't forget to rate me
thx
Posted on Jun 03, 2010
Testimonial: "that sounds like a bigger job than I'm capable of"
  • Big E
    Big E Jun 04, 2010
    go ahead and take it to a computer repair shop and ask if they can do that for you, they have tons of old hard drives, they may have one like yours and it should not be that expensive. maybe around 40 or 50 bucks
    Guru:
  • 1,705 Answers
I'd try another PC if you can, but as its already an issue on 2 pc's your drive could be faulty
My lacie hard drive turnes on ,shows that its running,stops running and keeps showing pink light but does not show appearance on my laptop,
Right click "My Computer" and select Manage. In the window, select Disk Management on the left column. If the drive is not listed on the right column, then the BIOS has not detected the harddrive - it might have a harddrive password lock. You will need to go into the BIOS and unlock it with the password.
Nov 01, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Lacie ext hard drive, 500 GB, doesn't show files but 123GB used
you can always recover your files with the program undelete . exe
verry good working tool.
if you are interested
Feb 13, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
My computer is not detecting my LaCie Hard Drive
there is a usb port inside hd .box /many time it is damage and also usb cablle damage . so once time change this thing one by one to check. there is a rare chance to damage hdd. we have facinge many time same problem. this hdd and laptop hdd are same. only potr is diffrent, (nepal)
Oct 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
PC no longer recognises LaCie drive
Hi Katya!
There are several possible causes for this. You didn't specify if you're running Windows or Mac so I apologize in advance if some of the information I provide does not apply.
  1. If you recently performed a Windows Update, there's a patch to fix your issue; http://support.microsoft.com/kb/925196#fixit4me
  2. There is a firmware upgrade for your external hard drive. It is located here: http://www.lacie.com/ca/support/drivers/index.htm?id=10007
  3. If the above solutions don't solve your problem, you may try uninstalling the device and reinstalling it. This should clear any communications errors it may have
I do hope I was able to solve your issue. I wish you the best of luck.
Greg
Jun 12, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
I have a LaCie 500 GB Exernal Hard Drive, everytime I plug it into my laptop it works fine for a few minutes (various lengths from 2 minutes to 20 minutes) then it causes my laptop to freeze. I no longer...
Are you sure it is not a power problem? If the drive has an external power supply then then will not be the case, but if not, the USB port might not provide enough power.
Also check out: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Apr 04, 2009 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
No external drive icon on desk top
This happened to me as well - i have been reading that it could be the power supply adaptor. If you can try another one - it might solve the problem. The adaptors seem to either be faulty or made to stop working. Great news for us the consumer!!
Dec 16, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie (300770) 250 GB Hard Drive Logo
612 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
