Question about RCA RS2664 Shelf System
CD changer The device powers up. I moved it from one shelf to another and it had CD's loaded. I read in the manual (leter) that you shouldn't move it with CD's loaded in it.
  • Anonymous Mar 15, 2009
    I tried removing the CDs manually and got four of the five out. The first CD is still all the way in the Stereo and I can't reach it. My CD player still won't open or play.
  • 2,326 Answers
Try to open the cover and remove the CDs manually. I'm sure that one of those CDs is not letting you open it.
Let me know if you need further assistance.
Posted on Apr 09, 2008
Bang and olufsen beosound 3000 does not read cd and loading stops. Can you help? Thanks
I never had like that. But "normally" there may be two reasons: CD fault or control board fault. Sometime main control keeps memorized wrong data and (in my Ouverture) CD unit simply is not responding and not loading - standing still. No way to move on except plugging off the power, press CD start on remote with no power, plug in power and try again. It clears bad data. I suspect it happened few times when I stopped CD player by remote or local main switch off.
Aug 19, 2014 | Bang and Olufsen Beosound 2000 Shelf...
I get E-01 error of my cd changer
The fault is actually inside the CD changer, when one disc is selected the changer moves the gearing inside to slot from one CD to the other.
While this operation is happening the selection arm jams !!
Then giving an error at the radio display..
To fix the problem, disconnect the CD changer from the trunk of the car,
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again,
grease the moving parts with light lubricant
Good Luck
Feb 24, 2011 | Mercedes-Benz C-Class Cars & Trucks
Powers on but CD shelf seems to be stuck?
we both have the same issue. Probably with moving it around, the CD system got pulled down. I fixed this by opening the right hand side wall, with the system upright, and shoved it towards the ceiling. Then I flipped it to the side and loaded the disc, and it worked. Make sure you disconnect the power before anything.
May 19, 2010 | Sony MHC-RG222 CD Shelf System
I have a Sony MHC-GX470 stereo...it will not play cd's...when you load a cd in it comes up with "mecha error"...the cd changer will not move between cd 1, cd2 and cd3 either.
the mechanism is bad or in human terms the motor that excepts and moves the disc has gone out i reccomend taking it to a repair shop to get a estimate because it may jus be cheaper to replace it.
Jun 26, 2009 | Sony MHC-GX470 Shelf System
CD changer goes in and out on its own. Then it stays out.
That model is known to have bad solder joints around the transformer in the power supply. I would open it up and resolder all the terminals of the large transformer, with the unit unplugged ofcourse, and then check to see if it works.
Jan 05, 2009 | Aiwa NSX-A115 Shelf System
CD Changer won't read CD
cd changer showing message display ERROR 2 . i CHECK THE MANUAL AND COMPLIED WITH ADVISE TO NO SUCCESS, WHAT IS WRONG
Nov 12, 2007 | Panasonic CX-DP801 8-Disc CD Changer
CD changer not playing CD's
If this did not help the problem by cleani9ng the lens, the laser is bad or the spindle moteo is bad. if this unit is over 2 years old, buy a new unit. Good Luck
Jul 14, 2007 | Aiwa NSX-A505 CD Shelf System
System won't let me play anything
You need to replace the audio amplifier IC because are damaged
Jan 16, 2007 | Sony LBT-W900AV Shelf System
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
RCA RS2664 Shelf System Logo
78 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
