Question about Kenmore 56939 Side by Side Refrigerator
Refirgerator intermittant water leak
Twice in the last 2 weeks my refrig has leaked onto the floor leaked into the basement - approx 1 gal of water - it stopped as fast as it started. I pulled it out but cannot seem to see where it's leaking....checked all the water fittings...looked inside the back...nothing....?????
  • 1462 Answers
SOURCE: refrigerator leaking water out
being in the uk, i don't know this appliance specifically so take this as guidence. there are two places where water can come from. at the rear of the fridge there should be a gully at the bottom of the evaporator wall - the part that frosts up. in the middle of this gully is a drain and this is likely blocked. push something flexible down it and check blockage is cleared by pouring a small amount of water in the gully and see it flows freely away. good idea to occasionly pour a small amount of dilute bleach down it now and again to keep it sweet. the other place for water to come from is if some of the contents of the fridge are touching the back wall. when it defrosts the water tends to divert onto the shelves
Posted on Apr 03, 2007
  • 92 Answers
check behind the drawers is there a water tank for water in thew door that would be my first guess
Posted on Feb 10, 2008
my kenmore frig side by side did the same I flushed the freezer drain like the instruction book says but it leaked on the floor after A week.
I pulled out the frig unplugged it in the back I removed the bottom black cardboard grille and vacuumed the underneath and removed the black drain tube and flushed water through it and put it back that solved the problem and took about 15 minutes to do I hope this helps people who are having repeat trouble.
Posted on Jul 20, 2008
tech master
  • 120 Answers
SOURCE: problem with kenmore side by side leaking
2 things could be wrong first is you compressor running if is not running you have to check the overload to see if it tripp if it did it will sound like a babys rattle just repl and compressor should kick back on if is running then is you evaporator motor running if is not then check for volatge at the wires if you get 118 then repl your motor. is the unit defrosting is there a lot of ice on the back cover it might not be so 3 thing might be failing 1 timer 2 defrost thermostat 3 heater coil call a tech to have those check out thanks
Posted on Oct 15, 2008
  • 11 Answers
SOURCE: water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Posted on Feb 04, 2009
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Kenmore Refrig leaking from bottom
close the water valve going to the fridge and call for service it may leak from many places is hard to tell blindly.
Jul 25, 2009 | Refrigerators
Water leaking into the refrigerator
Hi, You have a drain plugged in the frezer. Your model # doesn't come up but what you need to do is remove the rear anel in the freezer and clear the ice. If the floor of the freezer has two screws holding it, remove it as well.
Please check the model# again and I can assist you further. There is an after market deat transfer strip you might need to add to prevent this from reaccuring.
Thanks
Vic
May 17, 2009 | Refrigerators
My refrige leaks water on the floor from the freezer side on the left. I turned the water off and disconnected the water line. Still once or twice a week the refrige leaks water on the floor.
Sounds like ice build up on the freezer coils. Disconecting the water line doesn't stop regrigerant from flowing through the coils since they are still working. Easiest way would be a hair dryer to melt the built up frozen consensation. After you should see no water on the floor and you can turn the water back on (i assume the water is for your ice water and ice cube tray).
Apr 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Water on my floor
Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool® 4.6 Cu. Ft. Cabrio® HE Washer leaking water
coins may have breached the outer tub. expensive way to learn to remove loose objects fro clothes before washing them
Sep 14, 2008 | Washing Machines
Kenmore 56939 Side by Side Refrigerator Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
