Question about Abernook Pasquini Livia 90 Automatic
After several failures, I replaced the pressure stat on my Pasquini Livia 90, only to find that the water would not heat. I put back the old stat, but it still doesn't work. Can anyone help?
  • 1,089 Answers
Hi
Check the wire on the water reservoir to make sure that it is properly connected.
Check to make sure the wire connection is clean and making good contact.
If the machine turns on the connection is dirty, so you will need to remove nut and clean.
There is a level probe on top of the boiler (actually 2) The right one (yellow wire) is the low level probe and it will not let the boiler turn on unless it sences water at the probe. If it is scaled it can't tell if there is water in the boiler and the element will not heat. Remove and clean the probe.
Posted on Jun 03, 2010
I have an older Pasquini Livia purchased in the early 90s. It continues to heat up and then the relief valve goes off. Is there a thermostat to replace?
Yes, remove the top panel on the right side is a p. stat with a microswitch on top, either that has to be replaced or the tube is blocked and it cannot read the steam pressure.
Nov 10, 2011 | Pasquini Livia 90 Espresso Machine
This Livia 90 has been working beautifully for the last 5 years. Suddenly, the water does not heat up. The needle on the temperature gage reaches the point just before the red marking and then gradually...
Hi
If you open the steam knob before you turn the machine on and it heats up normaly, you need to replace the vacuum breaker valve on top of the boiler. Its the 3/4 hex nut with the little brass pin in the center. If its is stuck closed when the machine is turned off, its holds pressure in the boiler, so when you turn the machine on again it starts to heat up but reaches pressure fast and turns the element off before it heats up all the way.
Apr 25, 2011 | Pasquini Livia 90 Espresso Machine
Pasquini livia 90 will power up for only few seconds and then shut down you know what iy maybe?
Try this open the steam valve when turning the machine on, if that works then the vent valve needs to be replaced, or the p.stat is damaged.
Feb 18, 2011 | Pasquini Livia 90 Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Jul 21, 2010 | Pasquini Livia 90 Espresso Machine
I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
This is an early model livia 90 (~1994). Problem is no heating of water. Pump works but neither heating light or pump light comes on. I determined the power relay was not closing. Replaced it with new...
Hi
I would check the level probes on top of the boiler. There is a yellow wire going to the high level( left) and a green wire going to the low (right) probe. The probes get scaled and do not sense water. If there is no sensing of the right probe ( low water) it will not heat. They both need to be cleaned. There is a nut or a big nut that will allow for the removal. Clean both probes and it should go back to normal.
Dec 26, 2009 | Pasquini Livia 90 Espresso Machine
I have a 6 year old Pasquini Livia 90 Automatic. I have replaced the Pressure Stat (4 years ago). Now the machine shuts down after warming up with all three touch pad indicator lights blinking. The...
Hi
there are a couple things you might try. There is a screw in the top of the pressurestat. Turn the screw counter clockwise to lower the pressure.
The light should go off just before the 11:30 position on the gauge.
There are 2 probes on top of the boiler that needs cleaning every so often. A yellow and a green wire connect to the top of the probes. Loosen the small nut about 2 turns or all the way out.
Then pull on the probes to remove then. Sometimes it comes out with the white seal. that is OK. Clean the bottom of the probes and then reinstall.
Yellow goes on the left and green on the right.
Nov 21, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Tooo much pressure
If you remove the top panel on the machine there is a pressure stat on the right side, with 2 wire connections going to it. That P.stat could be damaged and needs to be replaced, or the pipe to the P.stat is clogged and it cannot read the boiler pressure.
May 13, 2009 | Pasquini Livia 90 Espresso Machine
Abernook Pasquini Livia 90 Automatic Logo
112 people viewed this question
Top Abernook Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Abernook Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
