Question about Maytag Atlantis MDG6400AW Gas Dryer
Running but not firing & heating
I actually have a MDG 6200 but figured they are pretty simple machines so it could be same.
Basically the ignitor fires sometimes and doesn't fire other times.
Most of the time the ignitor gets red hot, and then either fires or doesn't fire and makes a click noise when it doesn't fire.
Sometimes the ignitor doesn't get red hot at all.
Why the heck is it not firing?
The ignitor has no cracks or anything and I replaced it about a year ago and it has worked fine until now.
Seems like there is something telling it not to fire up.
Thanks!
    President:
  • 1,430 Answers
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gdryertroublevideo.html that will walk you thru this.
Posted on Jun 03, 2010
Bake does not work
most likely you have a bad ignitor,this is the first thing that goes,if it glows and doesn't ignite the flame within 40 seconds after it starts to glow the ignitor is still bad even though it glows orange.if it's a flat ignitor it takes 3.2 amps for the ignitor to open the gas valve and ignite the flame,if it's a round ignitor it takes 2.5 amps to fire it up.you don't have to shut the gas down,if it's a fairly new machine no electricity will go to the ignitor either if it's shut off but you can shut the breaker down if you want.the machines are not like the older machines where you lite it with a match,they are electronic ignition so check the ignitor first,if it doesn't glow at all you can check the ignitor for continuity with a meter.if you need any more help send the full model number off of the machine,open the bottom draw under the oven door,look on the frame,left or right side and you'll see a tag with the model number on it.good luck and happy new year.
Dec 30, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Car Takes Several Attempts to start
Nah... Robert Hofland,
The security key either works or it does not...
If the "DEALER" actually has a MECHANIC around...
That would a NICE (albeit unlikely).
YOUR Dealer ...
(In my opinion: needs a little integrity and / or a brain)...
Your can get "FREE" reads to get the
Diagnostic Trouble Codes (DTCs) pulled out
of your On Board Diagnostic System...
Don't buy anything... ESPECIALLY not Oxygen sensors...
just get the codes READ-OUT...
Come back here... We have some pretty good experience...!!
>> If it only does this when it is cold...
>> or when it has been standing...
Point to completely different troubles... but both in your
FUEL SUPPLY.
Getting those codes is PARAMOUNT.
Exhaust shops, parts stores... even some mechanics...
If it is something simple... You might be wise just to get
it fixed... or diagnosed & fix it yourself...
Pretty sure you are BETTER OFF not letting the
"dealer" continue at VERY BEST... being incredibly INCOMPETENT... dishonest... (creep... etc.
(in my opinion)).
Try it... Big savings... You will be proud.
Carnac the Magnificent
Jul 27, 2017 | 1998 Lexus ES 300
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
IM TRYING TO FIGURE OUT WHATS WRONG.I WAS DRIVING AND MY 89 TOYOTA PICKUP 3.0 4X4 QUIT RUNNING.WE FIGURED OUT FIRE WASNT GETTING TO THE PLUGS.WE INSTALLED CAP,ROTOR BUTTON,WIRES,DISTRIBUTER,AND IGNITION...
will try to help.try checking the ignitor assesmbly,with out it your truck will not get fire or low fire,so low you won't catch it. the ignitor gives it an extra boost of fire to ignite the gas in the cylinders. try that,but if it checks bad,used ignitors must match numbers with old onr. try used auto parts online. hope this helps and thank you for choosing fixya.com
Nov 28, 2010 | 1989 Toyota Pickup SR5
I can see my ignitor light up but it does not fire. About every third load it will fire and it dries a load just fine. But then it doesnt fire the next time.
@Mike,
I've been where you are and it can be frustrating! What you described, for lack of a better phrase, is an 'ignitor dying a slow death.' Within each heating unit (aka. ignitor) there is a tiny thermostat that tells the device WHEN to fire and how often. Your trouble can be fixed by replacing the part. If you supply your machine make and model number we can help point you to a replacement part which you can get online.
Thanks, Chris I.
Sep 08, 2010 | Dryers
Kitchenaid KGRT507FWHO gas range not firing or not getting hot
your ignitor is either cracked or bad
gotto sears type in your modle numbber and look for ignitor in parts search reletivley easy repair
Oct 07, 2009 | KitchenAid Cooktops
No fire to my plugs
Check your timing belt. Take the cap off, and turn the engine over to see if the cam is turning. If that's okay, , then, yes there is a diode in the distributor. And they are pretty pricey. If i was you i'd go get a distributor from an auto wrecker and replace the whole thing. It's easier, and cheaper.Good luck!
Mar 27, 2009 | 1994 Ford Crown Victoria
When heater starts it does not always light, I get a C3 code
the ignitor is faulty, mine also did that and I noticed one night that it was shorting out right from the ignition box. I put in a new ignitor and flame sensor and it's fine now. All ignitors are basically the same you just have to do some creative wireing. reddyparts.com still has most parts for your heater.
Jan 20, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Maytag Atlantis MDG6400AW Gas Dryer Logo
746 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
