Question about Logitech Cordless Mouse
Batteries will not recharge on stand. Have used different rechargeable batteries but same result
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 38 Answers
It could be the metal contacts that's used for recharging the mouse that isn't making a proper connection. The most common cause for this, would be dirt & oil that would build up on the charging contacts over time.
I would try to clean the contacts with a dry tissue paper on both the mouse and the charging stand and see if the mouse will charge properly again.
If that doesn't work, then maybe it's just the recharging circuit inside the mouse that's broken.
Posted on Jun 03, 2010
What type battery for powershotA480
Your camera uses 2 AA batteries, but if you use Alkaline batteries they will drain very fast. You are better off buying rechargeable batteries as you can recharge them several hundred times, cheaper than Duracell or Energizer Alkaline batteries in the long run. If you buy rechargeable batteries make sure you get a high mA capacity the higher the mA which stands for Milliamp Per Hour the longer the battery will last in terms of a charge.
Jun 20, 2014 | Canon PowerShot A480 Digital Camera
Tip
Digital Camera Problem - Shutting Off - Lens Not Retracting ?
If your digital camera shuts off sporadically or begins to malfunction, the fix could be as simple as replacing your batteries!
I was using AA rechargeable batteries when my camera starting acting up. My husband suggested that the batteries might be bad. While they were not new, they had only taken about 20 recharges over the years. I mistakenly thought they'd last for hundreds of charges despite age. As it turns out, rechargeable batteries have a shelf life.
Also, I had been storing my rechargeable batteries in the camera between uses. Remember, it is wise to remove any type of battery from the device if it will not be used for an extended period. This should help to extend the life cycle of your batteries.
Result: Upon installation of new, freshly-charged rechargeable batteries, my camera worked perfectly.
on Jun 19, 2010 | Cameras
My Canon Powershot A2000 displays a low battery even when I've just replaced with new. I've replaced several times, each time with two identical batteries, each time from a different package. I may be able...
For the best results, I recommend you to use Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Else......
AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
Feb 11, 2010 | Canon Powershot A2000 IS Digital Camera
Kodak Easy Share Printer dock plus. Original
you're not completely right. Kodak printer docks normally only charge the Kodak KAA2HR battery pack. It not charges normal Ni-MH rechargeable batteries of any brands.
Jan 12, 2010 | Kodak EasyShare Thermal Photo Printer
Will not power on
Did you use rechargeable batteries? The Garmin seems to be extremely picky about enough voltage. I had good rechargeables which I use in my foto flashlights, but they did not suffice for the Gamin. Simple non-rechargeable batteries ones solved my problem. Not good for the environment, but for my bearings...
Apr 21, 2009 | Garmin GPSMAP 176C GPS Receiver
Low Battery
Many Kodak brand cameras have this problem, and when I say many I mean almost all. The only solution is to try different types/brands of batteries until you find one that lasts.
Jan 17, 2009 | Kodak EasyShare C875 Digital Camera
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
Canon PowerShot A85
I decided to send you this from the Canon website to see if this helps:
Issue: What are the specifications for batteries that I can use in my camera?
Solution: Recommended AA batteries for your camera.
What types of AA batteries can I use? Canon rechargeable (NiMH) batteries For the best results, we recommend using Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
battery_charger_kit_cbk4_300.jpgThe Canon Battery & Charger Kit includes a battery charger and four rechargeable AA-size NiMH (nickel metal hydride) batteries. The battery kit can be purchase from the Canon eStore.
AA alkaline batteries AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
  • ALL AA-based PowerShot digital cameras (including A Series and S5 IS / SX100 IS-type):"Never use manganese (non-alkaline) batteries."
  • Since the performance of alkaline batteries may differ according to brand, the operating time of the batteries you purchase may not be as long as the batteries that came with the camera.
Precautions:
  • Camera operating time may shorten at low temperatures when alkaline batteries are used. Also due to their specifications, alkaline batteries may expire faster than NiMH batteries. If you are using the camera in cold areas or for a long time, we recommend using Canon AA-size NiMH Battery Kit (a four piece set).
  • While it is possible to use AA-size nickel-cadmium rechargeable batteries, performance is unreliable and their use is not recommended.
  • Never mix unused and partially used batteries. Always load two or four (depending on camera model) fresh (or fully recharged) batteries at the same time.
  • Be careful to load the batteries with their positive (+) and negative (-) ends in the right direction.
  • Never mix batteries of different types or from different manufacturers. All batteries should be identical.
  • Before inserting the batteries, wipe the battery terminals well with a dry cloth. Oil from ones skin or other dirt may cause a considerable reduction in the number of recordable images or reduced usage time.
  • Battery performance deteriorates at low temperatures (especially with alkaline batteries). If you are using the camera in cold areas and batteries are running down faster than they should, you may be able to restore performance by placing batteries in an inner pocket to warm them up prior to use. But be careful that you don't put the batteries into a pocket together with a metal key chain or other metallic objects, as these objects may cause batteries to short-circuit.
  • If you do not plan to use the camera for a long time, remove the batteries from the camera and store them in a safe place. Batteries may leak and damage the camera if left installed during prolonged periods of non-use.
WARNING
Never use damaged batteries or batteries whose outer seal is completely or partially missing or peeled off, as there is risk that such batteries may leak, overheat, or burst. Always check the seals on store-bought batteries before loading them, as some batteries may come with defective seals. Do not use batteries with defective seals.
Oct 26, 2008 | Canon PowerShot A85 Digital Camera
Rechargeable Batteries
This is a triky one. Most cameras will work with rechargeable batteries. If they don't work the most probable cause is this: a normal battery has about 1.5 V nominal charge. Because you use 2 of them you get 3 V nominal charge. Most rechargeable batteries have about 1.21 - 1.25 V like yours. This is given by the technology type used in their construction. However 2 1.25V batteries will result in 2.50 V at nominal charge and some cameras woun't go whell with the 0.5 V difference. You should try other types of rechargeable batteries, maybe some of them will work, but it is recomandable to do that before you buy them, so like I said, it's a triky choice. Try to go to a digital camera shop, they may sell rechargeable batteries more compatible with your camera.
Mar 11, 2007 | Fuji FinePix A500 Digital Camera
Logitech Cordless Mouse Logo
79 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
