Question about Rockford Fosgate T5001bd Car Audio Amplifier
Hi, I have a rockford fosgate mono amplifire T5001BD 2005 moldel. It seems to have a hiss sound coming from within the unit. I have opened it up and nothing seems blown or burnt. It lights up but the light is dim. Can this be fixed?
    Problem Solver:
  • 19 Answers
Maybe that's the cooling fan ur hearing if not make sure connections and tighten monitor the sound could be something goin bad
Posted on Jun 06, 2010
My rockford prime r500 1 keeps blowing fuses from the moment i put my main fuse in ?
Sounds like you have a short to ground.
Are you familiar with a DVOM at all, and do you own one ? Have you any electronic experience ?
Mar 21, 2013 | Rockford Fosgate Prime R500-1 500 Watt...
Hello, My rockford fosgate in dash unit is not
Are your rear speakers smplified or ran directly off of the radio?
Jul 29, 2011 | Rockford Fosgate Stereo Audio+video Rca...
I have a rockford fosgate t1500 amplifier and two 12"kicker L5's duel voice coil. the subs are wired together as one. they worked for about half an hour. now the amp and head unit comes on but no...
This amp is rated at 200 watts when run at 4 ohm load when in bridged mode (mono).You will need to check the measurement of the load at the amp's positive and negative location where it meets the speakers. You are actually going to need to measure the load of the speakers on the amp. If it ran too low of a load, meaning less than 4 ohms, there is a good possibility that the amp overheated and damaged some internal components due to not enough resistance. Some of their amps have internal fuses that can be replaced. It may be time to visit a diagnostic shop.
Bruce
May 04, 2011 | Rockford Fosgate Punch 201S Car Audio...
How do u bridge the rockford fosgate p325.1?
Hello... sorry you are having a problem. If you are running the 325.1, that amplifier is strictly a mono-block amplifier (1 channel) so it is not possible to bridge it. There are 2 speaker connections on the amp but both positives and negatives are connected on the circuit board in the amp. Hope this helps. Good luck with your venture.
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Rockford Fosgate Punch P325.1 Car Audio...
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
I have a rockford fosgate 550 that the fuse blows
Short inside one of the transistors. This requires very good soldring skills and electrical know-how, and some thermal paste to go between the heat-sink and the transistor. Unfortunatly this is not a cheap repair, probably cost around 100 dollars.
Cheers,
Kevin
Feb 09, 2010 | Rockford Fosgate Punch P550.2 2-Channel...
Hi..i would like to buy the Rockford Fosgate T10001bd parts .modle no' TO-247 75344G.Where can i buy please
Hi there are numerous places to buy parts for Rockford Fosgate amps. You can go directly to the support section at rockfordfosgate.com or there main repair center is landis tech in North Carolina. Or you can try Freemans car sterio Charlotte, NC
6500 E. Independence Blvd.
Charlotte, NC 28212
704.531.0550 ask for Jay in parts service. Thank you for using Fixya.com
Feb 07, 2010 | Rockford Fosgate T10001BD- Car Audio...
Hi could you tell me ,where can i buy the ROCKFORD FOSGATE parts?
Most electronic parts can be obtained from:
DigiKey.com
Mouser.com
Allied electronics (search for them in google)
Newark electronics (search for them in google)
Realize that SOME manufacturers hide the true part number with so called "house numbers" to mask their design.
Some numbers require educated knowledge to decipher. FOr instance, some transistors you might find might be marked as:
C4065 (Ficticious) this likely would be a 2SC4065... sometimes the 2S is left off...
Hint, when repairing damage, often you MUST use a current limiited power supply to avoid burning out new parts due to one bad one still in the unit.
Feb 06, 2010 | Rockford Fosgate T10001BD- Car Audio...
Amps that work with 10" RFZ2410
well how manny amps can the sub hold? any amp will work you can bridge it to doulbe the power but i would say a 200 wat amp would do you good
Aug 02, 2009 | Rockford Fosgate RFZ2410 Car Subwoofer
Rockford fosgate p6001db will powers on the r lights up but the spekers wont work
it needs to be repaired the pre amp is out if all your wires are connected right
May 04, 2009 | Rockford Fosgate Punch P6001b Reed...
Rockford Fosgate T5001bd Car Audio Amplifier Logo
71 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
