Question about Audiovox FPE1078 7.8 in. TV/DVD Combo
Plug in Inside the TV, the part that receives the plug, is broken. How do/can I repair it. Can we open the TV and is their a part to replace that or a way to repair the plug in receptacle. It looks split in half.
  • judith_miley Jun 04, 2010
    The power cord is separate from the tv. Inside the case of the TV there is a receptacle that receives the power cord. It is a case with a pin in it. The power cord plugs into that case. It is the case inside the TV that is broken.
  • missy27568 Oct 07, 2015
    I have the same problem and can't seem to find the solution for it.
    Scholar:
  • 121 Answers
You could open the TV up and follow the cord until you can find some kind of fraying or break in the cord or leads they are connected to. If it's the cable itself, you can solder them back together and wrap it in electrical tape. You just have to be careful about making sure the right wires are connected and that none of them are touching each other. Use the electrical tape to separate the wires so they don't short out and start a fire. If it's not the wire itself, then it's possibly the power supply it's connected to.
Posted on Jun 03, 2010
No sound from speakers sound only with headphones
You'd have to open up the TV back panel and look inside for why the speakers aren't working. A wire could be loose on one of the speaker connections or the amplifier for them is broken. An easy way around that is to use the headphone connection and plug into the aux port on a stereo/home theater receiver and use that for audio instead
Apr 09, 2014 | Polaroid Televison & Video
Toshiba Model 51H84. Power breaker tripped during a storm. Breaker reset, and TV will not power on. Is there a fuse? Is there a reset button of some sort? How should I proceed? Thanks.
Your TV has a fuse on power circuit board ( that is a standard part).You need to resemble your tv to get the fuse ( make sure to disconnect all power and antenna before doing this service). Usually any tvs use a clear glass cover on fuse ( you can see a small conductor inside the glass). Replace the fuse if the small conductor gets broken. If after the fuse replacement, you got no joy on tv, the receiver part could be get problem also ( due to storm attack) and need to repair / replacement.
I hope the storm only attack your TV fuse.
Good luck
Aug 02, 2011 | Televison & Video
My magellan will not charge from my car, only from my hose.
replace the cigar lighter. some plugs like my new phone will not plug in the lighter socket. It may have a broken contact inside the lighter. about a $10.00 repair job.
Deane
Nov 21, 2010 | Magellan RoadMate 1412 Car GPS Receiver
GPSMAP 178C Sounder GPS Receiver: My 178C will not stay powered up. I just replaced ...
I had the same problem with mine. It is caused by a crimped wire on the internal harness inside the machine. I opened it up and discovered that when originally put together 3 of the wires from the plug were crimped. One was broken off. The only way to fix it is to open it up, restrip the wires place a piece shrink wrap on before you solder it back and then make the shrink wrap flush with the back of the plug and heat her up. And, Voila... no more intermittent operation. Hope this helps? John
May 18, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Ribbon cable broken and now cannot open the face plate
You need to take the unit apart to fix the cable since the other end of it plugs into the board inside, it's pretty easy to take apart though. Good luck!
Feb 09, 2009 | Pioneer DEH-P8600MP CD Player
Problems with Magellan Maestro? 4040 GPS power connection
Wow if you opened the unit Magellan can tell. If your unit was under warranty You might have talked them into a repair (if your very very very persistent with you can get thin done , eventually ) but now you talk to them to see what they can do but it may be cheaper to go get another unit
Jan 12, 2009 | Magellan Maestro 4040 GPS Receiver
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Broken RF Connector
Its fixable. the question is how much of the inside broke with it. cost for repair on that usually averages 45 to 65 dollars... unless tuner is damaged in most cases not. if not hooked to tuner then maybe a new isolation block..simple job Good luck
Mar 09, 2006 | Zenith C27A24T 27" TV
Audiovox FPE1078 7.8 in. TV/DVD Combo Logo
315 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
