Question about HP Deskjet 6940 InkJet Printer
It says my printer is "offline" - how do I change this status?
  • 977 Answers
1. Make sure the printer is correctly connected and powered on.
2. Right click the printer icon (in Printers and faxes) and select "Use Printer Online".
Done!
Best regards,
Pelu.
Posted on Jun 03, 2010
  • Ran Kedar
    Ran Kedar Jun 03, 2010
    Try replacing the USB cable if the above solution didn't work for you
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Offline change
Just go to Devices and Printers from Control Panel, Right click on your Printer and click on See Whats Printing or Print Status, Once you click on it the Printer Spool Window would appear there click on File and make sure use Printer Off line is not checked. If its not checked and you have the same issue its an issue with the driver the Printer has to be reinstalled.
May 14, 2013 | Toshiba E-Studio 3040c Color Copier
To change print status "offline" to "online
Go to devices and printers to see if your printer is set to default. Make sure the printer cables are plugged in tight. Offline means it is not getting a signal . In Case You Still Having Problem Then Follow Us For On : Brother Printer Support
Aug 01, 2011 | Brother Office Equipment & Supplies
Go into printers and faxes in Xp or Printers and devices in Windows 7. Double click on the printer icon and click on file and then Offline and it will change to online. That should do it.
Jul 27, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
Printer showing offline
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Jul 10, 2011 | HP DeskJet 6988 Printer
Hp deskje d2360 printer showing offline error
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
How do i chsnge the status from offline to online?
Make sure it correctly connected then switch the printer on.
May 01, 2010 | HP DeskJet F380 All-In-One Printer
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
Printer light keeps blinking and status stays offline even it is READY
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
Nov 14, 2007 | HP Deskjet D2360 InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
187 people viewed this question
Seeker5211
Seeker5211
