Question about Mtd Craftsman 4Cycle Mini Tiller
Gas line wroughted and broke. replaced, but primer bulb wont work
There is a top and bottom gas line. One on top looks like it is just for air while the one on the bottom had the filer attached and sat on the bottom of the gas tank. After replacing both, i cannot get the primer bulb to fill up, and i am not getting any gas to the carb.
2 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: carb pumps air back into fuel supply line
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. You can also use the Den Tek Brush to clean the jet in carb. if it has one. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
Started reving very fast wont idle ;was the correct fuel mix was cutting on side ie not down
Check your all of fuel lines for cracks / air leaks especially near any fittings. Also check the primer bulb (if installed) for any pin holes. The symptom you describe is either caused by fuel starvation or the introduction of air into the fuel system. Also check inside the gas tank looking at the fuel pick up tube END / strainer for debris. Make sure that the gas cap remains vented. If some one has placed plastic over the fuel tank fill hole and then the gas cap it will perform as you stated. This model also has a mini fuel filter that can be clogged causing fuel starvation.
See this link:
http://www.ereplacementparts.com/poulan-p3314-type-gas-chainsaw-parts-c-16962_17147_17782.html
In DETAIL A
There is a fuel line item A7 and a tank purge device item A6 that is often where the air leak presents itself.
in DETAIL B
The primer bulb item B14 and the purge line B13 are also a major source of air introduction.
Once you get the feul system sealed again by repair of the fuel lines or replacement of the primer bulb you should be back in the wood cutting business again WITHOUT making carb aadjustments.
Thanks for choosing FixYa,
Kelly
Jan 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Troy bilt gas trimmer gas lines broke and now I'm not sure which lines go where.
The gas lines probably broke because of the ethanol-laced gasoline we have to use nowadays. It deteriorates them. If the unit has the external purge/primer bulb, the way mine did, it is not that hard. Just remember...the primer bulb "pulls" fresh fuel from the fuel tank to and thru the carb, thus pushing out any air/old fuel in the metering chamber of the carb back to the fuel tank in the return line...that said..
Fuel tank...2 lines...smaller diameter line goes directly to the carb body. There are probably 2 brass nipples on the carb. This line goes to the one on the body opposite the end of the carb with the vent-hole in the cover. This is the fuel pump end...where fresh gas enters the carb.
The larger line out of the fuel tank connects to the longer nipple on the purge/primer bulb. This is the fuel return line.
The remaining fuel line (larger diameter) goes from the vented-cover (has writing on it) end of the carb to the shorter nipple on the purge/primer bulb. This line carrys air and old fuel OUT of the carb to the bulb where it is then PUSHED back to the fuel tank via the return line...so you have a small diameter supply line to carb...an intermediate larger diameter line from the carb to the bulb and finally the larger diameter return line from the bulb BACK to the fuel tank.
Go to a small engine shop and purchase about a foot each of the 2 different diameter fuel lines needed and install those new "Tygon" fuel lines as your fuel line replacement.
Jul 09, 2010 | Troy Garden
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
How to replace gas lines on a Weedeater Excaliber Hedge Trimmer
My Bolens Weedeater runs for 3 or 4 seconds and stop but it will run only if I drop some gas in the caburator then stop. Can you help me with this problem?
Norris.
Sep 25, 2009 | Garden
Replacing broken gaslines... were do they go?
the primer bulb draws gas through the carb 'C' and back to the tank'T' leaving a small amount of fresh gas in the carb.to replace the lines from filter to carb & bulb to tank,you may have to remove handle & split the housing halves to find where lines enter tank.look in tank W/ a flashlight.to replace lines cut new line on an angle,feed a piece of # 14 copper wire through hole from inside tank.slide new line over wire,the wire will help align fuel line with hole.use needle-nose pliers to push line into tank,& to pull it through once you can see it.cut off end of hose you beat up with pliers.push filter on hose to carb.drop it back in tank."T' line is the return.dosn't matter which line is through top or bottom hole.
Sep 21, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Problem with primer bulb
Reverse the line connections at the primer bulb. Look carefully, the long port has the line going to the tank, the short port on the bulb will connect with the fuel line to the carb.
Sep 05, 2009 | Craftsman 25cc Gas Line Trimmer
Fails to stay running / primer bulb does not fill
Double check that the fuel lines are routed properly. Another place to look for a potential problem is where the fuel line comes out of the tank. Make sure the hose is not pinched. The typical fuel line routing is the first line (the one with the fuel filter in the end of it) comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb and the third line goes from top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 04, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replaced gas lines on ryobi 31ccweedeater. my have lines crossed. will not crank.
One fuel line (the one with the fuel filter in the end of it), comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to the top fitting on carburator. That should be the correct fuel line routing. Hope this helped and best wishes.
Aug 28, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
GAS LINE PROBLEM
Hi this is the way it should go: 1 from the filter in the tank to the bottom of the carby,2 from the top of the carby to the inlet on the primer,3 from the outlet on the primer back to the tank as this is the return line nothing goes onto it.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. if that doesn't work have the carb repaired at a service center or replaced.
Jul 05, 2008 | Ryobi 15" Electric Factory Reconditioned...
Mtd Craftsman 4Cycle Mini Tiller Logo
107 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
