Question about Ovens
Creda Capri Oven - Ignition
I have a Creda Capri C150G/L oven and the ignition sparker no longer works. I presume that the battery needs to be replace but I am unable to find out where it is located. Can you help please.
I downloaded the manual from http://www.manualsmania.com and here is the section on replacing the battery:
Use an alkaline AA battery.The battery holder is located in the plinth panel below the oven door.Open the oven door fully. Press the tag on the left hand side of the battery holder/cover and withdraw it just enough to get access to thebattery. Fit the new battery with the end marked "+" on the same side ofthe battery holder as the red lead. Replace the battery holder by pushingit firmly into the hole in the plinth.
Posted on May 10, 2012
3 Suggested Answers
SOURCE: How to change an oven lamp in a creda concept oven
were is bulb is it at back off cooker were wire mesh is
Posted on Feb 10, 2009
  • 30 Answers
SOURCE: grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Posted on Aug 21, 2009
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Apr 06, 2010 | Ovens
Main fan oven in Creda C130E won't heat. Everything else working ok. Suspect the element. Does oven have to be removed from its housing to replace the element?
If you remove the inner rear panl of oven compartment, you will see the element.
If you can see removeable screws, then you can change the element from inside without the need to remove from housing.
If screws cannot be removed from inside, then you will have to remove the oven from housing.
Please leave feedback for my suggested solution.
Thankyou.
Feb 16, 2010 | Creda Ovens
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
Creda Oven Model ESO 210 broken multifunction selector knob
Same thing happened with my Creda ESO 210. The function selector works find. It just doesn't rotate the piece of plastic that has the funtion symbols on it. I contacted the authorised parts supplier in Canada and was told it would cost $90 for the part. After a long wait, the part arrived and it wasn't the correct piece (they'd ordered the little plastic circle with the function symbols on it instead of the knob thingee that moves it). So, if that cost $90, I dread to think what the broken mechanism would cost. So, I gave up and I simply count the clicks from the off position to use my oven. However, if you really want to follow up on this, you can contact www.creda.co.uk.
Jan 20, 2010 | Creda Europa E010E Electric Single Oven
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
No gas coming through
Hi. you will need to replace two devices. you will need ot replace the ignitor and you will also need to replace the coil assembly that is located on the burner assembly. these two devices are faulty and, this is causing the interruption you are experiencing.
The coils actually control the gas valves. they provide the resistance that initiates the opening and closing of the valves and, the ignitor ignites the flame.
May 21, 2009 | Creda Ovens
Oven door
hotpoint/creda do a good spares service or try currys masterpart
Nov 12, 2008 | Creda Ovens
Ovens Logo
666 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
