Question about Brother IntelliFAX 4100 Laser Fax
Printing confirmations How do I setup to print confirmation for brother fax 4100e
    President:
  • 405 Answers
Press MENU button, then the numbers, 2 ,4 ,1. Then press the left and right arrows to find On and then press the SET button.
Posted on Jun 06, 2010
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How do I set the Fax 2910 Brother to print a fax confirmation each time? Thanks
Using the Reports Key
Five reports are available:
1 HELP LIST: Prints the Menu Table so you can see at-a-glance how to quickly program every menu selection.
2 AUTO DIAL: Lists names and numbers stored in Speed Dial and One Touch Dial (FAX models only) memory, in numerical order.
3 FAX ACTIVITY: Lists information about the last 200 incoming and outgoing faxes. TX means Transmit; RX means Receive.
4 TRANSMISSION: (CONFIRMATION) Prints a Transmission Verification Report for your last transmission.
5 USER SETTINGS: Lists settings for GENERAL SETUP, SETUP RECEIVE, SETUP SEND, SETUP REPORTS, and TEL SERVICE.
The settings for REMOTE FAX OPT are included.
Jan 18, 2011 | Brother IntelliFax-2820 Laser Fax
Confirmation page shows zero pages sent. Is there a way to set to show the number of pages sent
I would first test a fax to see if it completes on your end then is received on it's entirety on the receiving end. Then print a fax transmittal report to confirm. Once that shows success, print your polling fax report and verify.
If it says zero pages sent, chances are the fax failed.
Jan 14, 2010 | Brother IntelliFAX 4100e All-In-One Laser...
How to set up for confirmation sheet.
You can use the reports button or menu button to reports, and print out the user settings list. It shows where the settings are, and what they're set on. In fax setup you can select frequency of report printing, but the Brother machines always give a printout if a fax fails.
Oct 09, 2009 | Brother IntelliFax-1860C All-In-One InkJet...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Printing all document out the back of machine
There is a lever in the back, lift it will divert the papers to the front again. ( looks like a small door)
Dec 09, 2008 | Brother IntelliFax-4100e Fax
Confirmation page from days earlier
check the device for an activity log option. you may need to check the user manual for this.
Mar 06, 2008 | Brother IntelliFAX 4100e All-In-One Laser...
4100E machine
Go into the menu & select fax. Using the forward arrow go to fax, then set up reports, then transmission. that is the area where you turn on the confirmation page to print.
Jan 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Confirmation Printout
Yes go into reports on the operation menu. use the arrows to get where you want and confirm by hitting set.
Nov 13, 2007 | Brother IntelliFax-4100e Fax
Brother IntelliFAX 4100 Laser Fax Logo
409 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
