Question about HP Pavilion dv6000z Notebook
For knowing warranty period
Ma laptop's battery backup is very low,its only 10 minutes.
  • David Joseph May 11, 2010
    hi there,
    need to know the make and model of your laptop... also the battery type
    Scholar:
  • 75 Answers
i think its time for a new /replacement battery..
but first let the battery completely discharge then let charge for a min. of 8 hours if the power is still below normal after 5-15 mins. of use change the battery.
Posted on May 01, 2008
    Master:
    Sergeant:
  • 482 Answers
Its time to replace the battery.
Posted on Apr 10, 2008
How long a car battery will last?
There is no definite user period on batteries and that is why there is a warranty. Factors affecting the life of a battery are ambient temperature Cold weather affects batteries that are below good condition. Charge rate --over charging boils of batteries and buckles the plates--Low electrolyte levels affects the life as it causes sulfation of the plates. --vibration of the battery removes the lead paste from the cell plates and reduces the life of the battery (Diesel engine problems). High discharge rates over heats the battery cells and buckles plates causing internal shorts.---crap around the terminals and on the battery posts reduces the ability to pass current and so the battery appears flat /and /or will not charge.
The brand of the battery and the price is no guarantee to quality and long life but proper battery care helps.
Oct 04, 2014 | 2010 Mercury Milan
Lenovo laptops
1. Check to make sure that you have good air flow around the laptop, including sides and bottom.
2. Make sure fan/heatsink area is clear of dirt, etc. If you are using the laptop in an environment where there is a lot of dust, it will clog up the fan/heatsink.
Check the Lenovo support forum to see how the clogged heatsink looks. https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/Y560-overheating-and-shutting-down/m-p/677023
Be aware to get to access to the insides, will require dis-assembly of the laptop. Best left to experts.
Apr 04, 2014 | Lenovo IdeaPad Z560 Laptop
Why does battery beep and tells me its on battery power when it's stil plugged to wall. and i have a good power source
Usually that indicates a low battery charge or bad battery. Make sure you do not have the battery backup side overloaded with too many devices. Do not plug inductive loads with motors or heating elements into the backup. Turn the device off and unplug anything that is plugged into the bachup. Plug the battery backup into the wall with nothing attached and turn on. Wait 10-15 minutes. this will charge the battery. If beeping continues after this with nothing attached, you likely need a new battery or the control/monitoring system is bad. If beeps stop, reinstall and do not attach more wattage than the unit can suppluy
Jan 06, 2011 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
Dear engineer i have acer 5630z laptop - if you
Is the laptop under warranty? If yes, then take it to the authorized service station, they shall repair it free of cost. If not, then how old is the laptop? How much battery backup does it provide when it is fully charged?
May 18, 2010 | Computers & Internet
Windows freezes after startup
Its better to backup your data - booting from Ultimate Boot CD and backup to an external hard drive.
Try to do regular format or low level format to know the status of the hard disk
Feb 07, 2010 | HP Computers & Internet
Battery does not hold charge;or battery discharges completely after about 5-10 minutes of use.
Charge the thing over night and try again. Nothing? Get a charger you know that works great and charge again. Still nothing? Your battery is shot and needs replacing. Have Apple do it for free if your still under warranty. If your out of warranty and low on cash, then get the battery kit from e-bay and then go on you tube and watch the instructional videos.
Aug 30, 2009 | Apple iPod classic 6th Generation Digital...
My Powercom UPS battery backup is lasting for 5 minutes than it is shutting down.Can you provide me the solution. Model No. is 2200APRM1320W It is very urgent, please.
The UPS can temporarily provide power to IT hardware in the event of a disruption to the Mains power supply. The UPS should stay powered up for long enough to enable the hardware it is protecting to be powered down in a controlled manner, before shutting off itself. The 5 minute period seems reasonable for such a task (although significantly less than the rated time), and if at any point within that period the Mains power supply comes back online, the hardware could continue to work.
I note that this particular model is supposed to provide battery power for 85 - 95 minutes. The amount of time it can supply regulated voltage for will depend upon the load placed upon it. The greater the load (in terms of current drawing devices), the shorter the amount of time that the UPS will be able to provide power.
There may be a Manufacturer Limited Warranty period (parts): 2 years for this model, although labour charges will probably be made.
Jun 08, 2009 | Computers & Internet
Baterry Backup only rest for 10 minutes
its better take your laptop to the service centrel and complain about the battery status there, because your laptop is still under warranty, its better to avail the warranty
Nov 06, 2008 | HP Business Notebook 530
Low Battery DATA Lose - HP iPAQ Model h5450 Packet PC
The h5450 comes with what HP calls a backup battery. It is built into the device and not accessible by the user. However, the backup battery has only enough juice to power the Pocket PC for a few minutes while you change main batteries. Don't expect it to keep your RAM data alive if the main battery runs out.
Mar 12, 2008 | RIM BlackBerry Pearl 8100
HP Pavilion dv6000z Notebook Logo
114 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
