Question about Mitsubishi WD-73827 73" HDTV DLP TV
Device button Why does my tv turn off everytime i choose the device button?
  • 505 Answers
A lot of mitsubishi tvs have faulty buttons or switches. It is likely this (unhooking the control panel will solve) or could be a faulty device that is crashing your tv (hdmi is really the only possible input that can do this)
Unhook all inputs, or just change devices on the remote. If it apprears to be the buttons, you can disassemble the tv to find the wires that go to the button assembly and unhook there and just use the remote from there on out. You could also repair ($20 plus time) or get it repaired - estimate = 150-250
Posted on Jun 03, 2010
ASUS ZENPAD 102300 C PROBLEMBS ALWAYS After cahrging. It wants a reset everytime
Have you checked for firmware updates? You can try to do a hard reset which can force OS errors to clear up.
First method:
  1. In order to switch off the device, hold down the Power button for a short while.
  2. In the next step press and hold Volume Up + Power key at the same time for a few seconds.
  3. You can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Factory Reset", and press Power button to confirm.
  5. Success! The hard reset has just been performed.
Second method:
  1. Turn on the device by using the Power button.
  2. Afterwards go to Settings and then to Backup & Reset.
  3. Tap Factory Data Reset and select Reset Device.
  4. If it's necessary enter the safety code and choose Erase Everything
  5. Select OK to confirm the whole operation.
  6. Well done! After a while your tablet should be ready to use.
Third method:
  1. At the beginning press the Power key to turn off your device.
  2. Afterwards press and hold Volume Up + Power simultaneously for about 5 seconds.
  3. you can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Recovery", and press Power button to confirm.
  5. Press Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm.
  6. Select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select.
  7. To restart the tablet, select "reboot system now".
  8. Success! The hard reset is done!
A Hard Reset will erase all of your data
Feb 16, 2017 | ASUS Computers & Internet
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
NEED TO PROGRAM MY RCA TV WITH A HUGHES HRMC-13 REMOTE
Hello
Codes for RCA tv with Hughes remote are:
160 161 156 165 065 070 004 023 024
056 074 081 152 167 145
Code Entry
Use the REMOTE pane under the System Setup menu tab to program your
HRMC-11, HRMC-12, or HRMC-13 remote control to operate your TV, VCR,
SAT, AUX device, or DVD (HRMC-11 and HRMC-12 only). The AUX menu
button can be used to control a CATV box or other type of device. Use the menu
buttons to choose the desired type of device and display a brand name menu list
from which you can select the manufacturer of your device.
Code scanning
To use the Code Scanning method:
1. Repeatedly tap the top part of the CHANNEL (CH) button.
2. Continue to step through the codes until the component turns off, indicating
you have found the correct component code. If you accidentally pass a code
that responds or realize you may not have been aiming the remote control at
the component, tap the lower part of the CHANNEL (CH) button to step
backward through the codes.
3. Press the remote control POWER button to verify the proper code by
turning the device on and off.
4. Press the device button (in this example, TV) again to lock in the code.
OK
Feb 20, 2011 | Televison & Video
How do I reprogram a Brookstone TV remote (large one)?
  1. 1
    Turn on the electronic device that you want to control with the Brookstone remote.
  2. 2
    Locate the "Set" button and the "Power" button on the remote. The "Set" button is located directly below the "0" button. The "Power" button is located in the top right corner of the remote.
  3. 3
    Press and hold the "Set" button and the "Power" button simultaneously. This illuminates the LED icon located at the top of the remote control.
  4. 4
    Press the button for the device you want to control. You can choose from "TV," "VCR," "DVD," "CAB," "SAT" or "AUD." The LED icon at the top of the controller will flash once.
  5. 5
    Point the remote at the device you are trying to control, and press the "Channel Up" button on the remote control followed by the "Power" button. This performs a quick search for the device's code.
  6. 6
    Press "Enter" to store the code if the device turned off. If the device didn't turn off, repeat steps 5 and 6 until it turns off.
Nov 02, 2010 | Televison & Video
Sharp tv ...want to use Rca remote D770 how do I program the remote?
Press and hold the device button you want to program (TV). Then type in one of the codes for Sharp TV's:
1004, 1006, 1012, 1029, 1095
1111, 1112, 1113, 1122, 1171, 1173
Release the TV button and press the on-off button. If that doesn't work, press the device button and try the on-off button again. Continue trying codes until one works.
Another thing to try: Turn on device. Press and hold the button for device you want to program, press the on/off button and hold until the LED turns on, and then release both buttons. Then, point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing. If the device does not turn off, then continue to press play and wait the required interval (for a maximum of 20 times) until the device turns off. When the device turns off, stop pressing play. Press REVERSE, wait two seconds and continue doing this until the device turns back on. To finish programming, press and hold STOP until the LED turns off.
If neither of these methods work, the remote probably isn't compatible with your TV (manufacturing dates matter; newer tv's often don't work with older universal remotes). In that case, try remotes.com for a exact duplicate of your TV's original remote. http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=19C140&uuid=12795625009490
I hope this helps.
Jul 19, 2010 | Sharp 19C140 19" TV
Trying to find a tv code for an Apex TV using a RCA universal remote control
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code (apex is not listed for this remote)
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Nov 16, 2009 | Apex Digital AT2002S 20" TV
JUST BOUGHT AN OPEN BOX TOSHIBA T.V. MODEL #26LV61OU LCD-HD AND IT DIDN'T HAVE A REMOTE. IT'S WORKING WITH MY VERIZON FIOS BUT I CAN'T CONTROL THE SOUND. WHAT TYPE OF REMOTE SHOULD I GET FOR THIS T.V. AND...
The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
2) Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons. The mode buttons blink twice.
3) Press 922.
4) Point the remote control toward the device you are setting up and press the upper part of the Play button.
5) Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
Note:
There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
  3. Press and hold for six seconds the device button for the device you turned on in step 1 (AUDIO, DVD/VCR, TV, CABLE).
  4. The lights for each device button light up and the light for the device button you selected remains on.
  5. Press the Power button on your remote.
  6. The device button blinks three times then turns off.
  7. Press the Up arrow button (this is the button directly above the OK button, not the Page Up button).
  8. Did the device turn off?
    Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
    No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
    Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
  2. Press and hold the Select button while also pressing the device button for the device you turned on in step 1 (AUX, DVD, VCR, TV, CBL) until the device button blinks twice.
  3. Press 991.
  4. The mode button blinks twice.
  5. Point the remote control toward the device you are setting up and press the Play button.
  6. The remote control tests each code in its library. The mode button blinks once each time the remote transmits a new code. When the last code is reached, the mode button blinks twice.
  7. When the device powers off, press the Select button.
  8. Verify the new code is correct by pressing the Power button.
    Did the device power on again?
    Yes: Press Select to assign the code in your remote control.
    No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
___________
One of those three should work for you.
Hope that helps.
Oct 02, 2009 | One For All URC-3021 Remote Control
Codes:RCA univ combo remote[rcr311w] to orion tv w/install procedure
try one of these
Orion191, 035, 208
the codes above may work with your tv. might not though.
use the codesabove to try it.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
Oct 01, 2009 | RCA 3-Device Universal Remote
Need to how to set remote philips TV an DirecTv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
these steps will set up the first device and then to set up the second device just repeat the steps choosing the other device and the code for it.
CODES: for the tv: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0019,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
for the direct tv: 1049,1766,1767,1768,0622,0632,0629,0623,0576,0586,0616,0613,0630,0634,0636,0638,0641,0652,0653,0657,0659,0607,0619,0537,0538,0539
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Philips Magnavox Learning Universal Remote
I am lookin for a code for a universal philips remote to use on a zenith tv dont know if this is waht yhou do but it came up int hte search for what i asked for
Direct Philips Magnavox Universal Remote Code Entry PM335
  1. Press and hold the Code Search button until the red
    indicator stays on.
  2. Release the Code Search button.
    Press and release the desired mode button likeTV,
    DVD)
    The red indicator will blink, then stays constantly lit.
    Enter the 3 digit code as below.
  3. Please note: The red indicator will turn off if code entry is valid but will flash for invalid codes.
  4. With the device on, press CHANNEL Up. No further programming is required should there be a response from device. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
TV
ZENITH ............. 241 142 345
Aug 15, 2008 | Televison & Video
Mitsubishi WD-73827 73" HDTV DLP TV Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
