Question about Kitchen Appliances - Others
I BOUGHT MY HOUSE WITH AN ECOWATER SYSTEM, BUT I
I BOUGHT MY HOUSE WITH AN ECOWATER SYSTEM,(WATER REFINER W/ELECTRONIC DEMAND). THE SCREEN SAYS THAT NEEDED RECHARGE . I PRESSED THE CHARGE BOTTON AND INMEDIATELY STARTED TO FLOSH WATER FROM THE LITTLE HOSE, SO I CONTINUED PRESSING THE THE SAME BOTTON, THEN STOP AND THEN FLOSHED WATER AGAIN. FINALLY STOP AND THE SCREEN CHANGED FOR ''RECHARGE AT 12:OO PM. DON'T KNOW WHAT TO DO. SOMEBODY KNOWS? PLEASE HELP. THE ONLY NOMBERS I CAN SEE ARE 7096264, HELP PLEASE... THNKS A LOT. ANNETTE
  • 3 Answers
SOURCE: Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Posted on Dec 28, 2008
  • 1684 Answers
SOURCE: How to solve CMOS checksum and timer errors?
Your backup battery is to weak to save the cmos data. Open your computer case and look for a round silver battery that looks like a quarter. Remove it and go to Radio Shack or a drug store battery section and get a replacement. The battery number is probably CR2032 but may be CR2025 or CR2016. insert the new battery and power up your computer, this time when you set the time and date the settings will stay when you turn it off.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 12, 2009
Testimonial: "Thank you very much. It's really helpful to me ♥"
SOURCE: problem with my door locks on my 2000 toyota 4runner limited fwd
I wish I had the answer. But, I have the exact same problem with a 1999 4runner. Hoping someone has the answer. The dealer I purchased it from just replaced the actuator, still no good. One dealer said maybe the master switch, hopefully not, they said that part is $400. Maybe a relay going bad?
Posted on Nov 02, 2009
  • 2501 Answers
SOURCE: the watch has an alarm that goes off at 10:17 pm,
Go to the casio web site "www.casio.com/support"
select "manuals"
Select "watches"
Select "watch manuals archives"
Enter details of you watch and download instructions.
Posted on Jan 06, 2010
SOURCE: water/ice dispenser sticking on
We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the rubber activator boot was pulled off. The dispenser stopped once the button attached to the back of the boot was removed. Nothing was physically broken (i.e., parts intact) but the challenge was to get things (especially the boot) back in place. The key for me was to use patience: researched Internet for pointers (not too helpful), looked for schematics (even less fruitful) and exhaustively examined the panel on refrigerator (to help reverse engineer). Okay, here’s how I disassembled and reassembled without breaking any tabs or other pieces. Assuming your unit is similar, the panel is on the freezer door on the left side. You can lock the dispenser (using panel button) to preclude undesired water/ice while working. Note: the outer bezel (edge of panel) is secured by screws and should not be messed with. The main panel has tabs on all four sides. I used three screwdrivers (small to average in size) to pry the panel off. Pry the main panel working through the seam between the bezel and panel. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Methodically work your way around using moderate force to pop the tabs loose. Once the panel is loose, you’ll need to disconnect the electrical connector at the upper left. The plug comes off and reattaches easily…don’t pull on the wires, use the plastic connector itself. Wiggle the panel free. Now you can get to the back of the boot retention bezel…the ultimate goal. Carefully push the bezel’s securing tabs (x3) through the panel and reattach the rubber boot. I used needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side—it’s the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle. Slide the right and bottom sides on first—flanges, not slots for tabs—then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place. Finis! (No guarantees, but this procedure worked like a charm for me.)
Posted on Mar 14, 2010
My Kenmore Ultrasoft 400 water softener tome light will not stop blinking. How do I reset it
It's been 10 years since I worked at EcoWater, but the Kenmore Ultrasoft 400 shouldn't have changed much. The brine tank light shouldn't blink at all. It should light for 4 minutes and then go out if you leave the door open if I remember correctly. How old is your softener and does it have a light bulb or an LED to light up the brine well? It's most likely a damaged control board that's creating your problem. You'll have to contact Sears for a replacement.
(EcoWater Systems LLC is the OEM [Original Equipment Manufacturer] of water softeners for Sears Kenmore, GE, Whirlpool, Morton Salt, EcoWater Systems dealers and a few others.)
Sep 03, 2016 | Water Dispensing & Filtration
Manual for ecowater reverse osmosis system
go google and type in --user manual for (make and model ) reverse osmosis system
if there is one it will be a pdf version for down load
Nov 16, 2015 | Refrigerators
I used equity on my parents home to buy my new house. I have already paid off the equity amount borrowed with westpac but they will not release my parents home.
It sounds like it is time to refinance your house through another lender. If you originally bought in 2006 you can probably get a lower rate anyway. Once you refinance the home and pay off the original loan the original lender has to release any lien on your parents home.
Mar 07, 2014 | Computers & Internet
A12 volt battery was hooked to system instead of the 6 volt can unit be saved
More than likely the internal fuse will have blown.
Steps: Remove a side of the housing (about seven screws) (even one under the knob decal) locate the circuit board in upper front area. locate fuse on circuit board behind water seal remove and replace fuse and reseal refit circuit board refit housing and decal cross your fingers, say a prayer, ready for testing now your there...good luck !
Nov 17, 2010 | Coleman Hot Water On Demand
I have a summer house and would like to heat the house in winter while I'm away to keep the humidity out. The problem is there is often breackdown of electricity. What must I do@
Hello,If unoccupied during the winter so what,Assuming the house water is off & drained.#1 get a generator for the house with auto demand start.#2 install a millivolt steam heat system (makes it's own electricty to operate)#3 the burgular alarm system can have tempature alert added so you get a phone call if the house gets too cold.Just an idea.
Oct 15, 2010 | Toyotomi TIN/TIG-329D Air Conditioner
No flow from EcoWater undersink filtration unit. Flow stopped so we changed two carbon filters and one sediment filter. Still almost no flow.
The water storage has probably lost its charge. A 3 gallon tank should have 7 psi pre-charge pressure. Tank has to be totally empty to set pre-charge. Turn water off to RO, pump air into tank to force all the water out at faucet, turn tank valve off and relieve pressure until 7psi charge.
RJ
Nov 28, 2009 | Culligan Under Sink Water Filter
On-Demand Water Heater
An on-demand, or tankless, water heater is a system for heating water as it passes through the pipes, usually very near the point of use. Traditional tank water heaters bring the water to approximately 140 degrees Fahrenheit (60 C), in order to ensure the water supply lasts long after the heater turns off. Since this is obviously far too hot to be pumped out of a shower of faucet, cold water is added to the mix in the pipes. Coupled with the loss of thermal energy over time, the average tank heater has an efficiency of approximately 80%. On-demand water heaters have a number of advantages over their tank-using counterparts. While tanks often degrade over time and begin leaking, the apparatus used in an on-demand water heater is much less susceptible to the burdens of age, and will often outlive the house they're installed in. The amount of energy used is a fraction of that used in a tank water heater, due to increased efficiency and a much smaller window during which a heating source is in use. While tank hot water heaters can, and often do, run out of hot water after a number of showers, on-demand heaters provide a never-ending supply of hot water, ensuring that warm water is always available when needed. A tankless water heater can cost between $500 and $1500, and they most commonly use either electric or natural gas energy to heat the water. Most mid-sized households report an energy savings of approximately 25-45% for a gas or propane heater, and up to 50% with an electric heater, over using traditional tank heaters. Water is usually set to a maximum temperature of 120 degrees Fahrenheit (49 C), though many heaters allow for custom setting of the maximum temperature via remote control. Outflow rates range from 8-14 gallons (30-53 litres) per minute. Installation for most tankless water heaters is incredibly easy, involving simple plumbing. In the case of electric heaters, all that is required for a fuel source is to plug the heater into an outlet and begin heating your water. Some modern on-demand water heaters can incorporate a solar preheating system. This system uses a traditional solar heating system and tank to bring the water nearer to the desired temperature, saving substantial energy use in the final on-demand heating. A solar preheating system costs between $500 and $800.
Aug 27, 2008 | Stiebel Eltron CK20E Electric Tankless...
BOSCH AQ125FX TANKLESS WATER HEATER
these heaters work when a pressure drop is sensed in the water supply line. The pressure sensor is likely blocked with sediment from the city supply. You may want to call for service.
Apr 27, 2007 | Terminator Aquastar 125FX Tankless Water...
Kitchen Appliances - Others Logo
97 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
