Question about Acer Aspire 4720 Notebook
My laptop gave me no problems except for occasionally going into hibernating and not being able to wake it so i would have to manually shut it down and turn it back on. but last week i dropped it and cracked the led lcd screen i send it into acer to get it fixed and paid $200 because cracked screens arent under warranty so i sent it in they fixed it and sent it back with a note saying they also updated my bios. Now since i got it back it turns off on me keeps going into a check disk screen where its finding errors and fixing them its been getting really hott. i charge it and then when i use it the battery only lasts about and hour. idk whats wrong any ideas??
    Guru:
  • 592 Answers
The BIOS update could have caused the unit's fan regulation to fault.
the check disk and actually fixing errors woudl point to the Hard Drive being damaged and needs to be replaced. A full diagnostics is what needs to be done to determine this, i would tell you how but multiple hard disk brands are used on these systems.
The BIOS update may have also changed the performance settings on the unit, this will cause the system to use the CPU maxxed all the time. This will kill the battery quicker. You can check this setting in yoru BIOS.
Posted on Jun 03, 2010
Testimonial: "WOW THATS WHATS HAPPENING MY BATTERY IS DYING SOOO FAST AND MY LAPTOP HAS BEEN GETTING HOT"
Acer 1916
Go into control panel, power options, go to hibernate, "top right" and click. Uncheck hibernate box, next! power schemes, " top left " and click, go down lelt side, "system standby " select never from the list and close window. This will prevent your laptop going to sleep, shutdown windows when you are finished.
Apr 23, 2012 | Acer Computers & Internet
Toshiba satellite laptop won't wake up from hibernation even after holding power botton down?!
If pressing down and holding the restart/start button doesn't wake it up you might try Control + ALT + DELETE keys (together) - that will reboot it though. And if that won't work then you might have to pull the battery to reset it.
It seems that some laptops have a problem with vista and sleep mode, in particular, and sometimes hibernate too. You can try going under POWER OPTIONS under Control Panel and setting everything back to default, saving it, then resetting it again. Also it's best to avoid using sleep mode if possible to avoid problems.
If the problem developed after a recent install or updating you may need to go to an older store point to fix the problem. Personally, I just avoid using these settings as much as possible and use regular shut down and a screen saver for times when I need to step away from laptop for short periods of time.
Apr 27, 2011 | Toshiba Satellite Pro L300 Notebook
Computer goes in to sleep/ hibernate mode and I can not wake it up without shutting it off, and restarting
If we are talking "hibernate", then that's what the computer does - it saves the whole memory contents on the hard disk and shuts down. You then have to power it up and it boots like always on power up, but instead of loading the system the usual way, it reads the hibernation file and restores the state in which it was when hibernated.
"Sleep" or "standby" mode is different - the system stops execution of all the running programs, switches the processor into low-speed, low-power mode, executing only the basic functions of waiting for wake-up signal. Depending on machine and settings, it will be woken up by keyboard event, system event (like laptop battery running out - time to hibernate), network activity, or the power switch.
It should wake up when the Fn key on keyboard is pressed, the lid is lfted up (if it was closed of course), or when you momentarily press the power button. If it does not, then something is wrong with your ACPI/Power Management setup, and/or there are some drivers missing or corrupt. You can try going to IBM/Lenovo website and looking for updated system drivers for your model.
Dec 03, 2009 | IBM ThinkPad T43 Notebook
Cannot wake up computer after putting it to sleep -- HP Pavilion -- I have pressed every concievable key combination ? Computer may be waking, but monitor is blank.
I rebuild these systems all the time and I have to tell you I just shut off the hibernation which is what the problem is. Go to power options in the control panel and click the hibernation tab and uncheck the box. That way you save the disk space and the aggravation of trying to wake up the system. Let the computer go into standby if you want but you really need to turn off the hibernation...
Oct 05, 2009 | HP Pavilion dv6000z Notebook
Not waking from stand by on windows xp sp3
dont keep doing it, at some point your laptop wont ever comeback to life. so just use shutdown and hibernation
Mar 25, 2009 | HP Compaq nx7300 Notebook
Can't wake up....gone into sleep mode...how do you wake it up
press and hold the power button down for about 5 secs. The computer will shut down. Restart it and right click on the desktop, go to properties then look for screensaver tab , then choose power options, click on hibernation tab at the top and uncheck enable hibernation. Or choose stanby options and choose a longer time before the computer goes to sleep.
Mar 21, 2009 | IBM ThinkPad T23 2647 Notebook
When I put the computer to "sleep" it decides to come back on by itself. This happens frequently, but not all the time. What could be causing it to do this? Also, if I shut the computer down,...
Sleep on Vista is a combination of Standby and Hibernate. First it will go into Standby and then later if a laptop it will go into Hibernate. Any movement of mouse or keyboard may cause it to wake up.
Some computers will wake on Lan. If you have ethernet connected this may be the cause. You can turn this off by using Device Manager - Hardware - Select ethernet adapter - driver - Advanced - look for Wake on Lan and Pattern Matching and disable this.
ALso check your BIOS settings and disable all Wake on XXX settings.
Nov 15, 2008 | HP Computers & Internet
How to turn on toshiba satellite M300 laptop from hibernating mode
hi shirleygty, is that automatic hibernation (the computer hibernates by itself) or manual hibernation (by pressing the hibernate button)? If either applies to your case you might need to update the BIOS information for your computer to fix the power management issues on it. You can get it here. Just run the file, click install & choose Install From Windows. Make sure you don't have any BIOS password or any external devices connected to the computer. When the update completed successfully, your computer will automatically restart, then try hibernating this time (manual or automatic). I do recommend setting the hibernation to 1min. at the control panel > power options > change when to turn off the display. When it hibernates, pressing any keys or the power button should wake up the computer.
Hope this helps.
Oct 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Compaq notebook presario C304NR hibernation
take out the battery, then put it back it. restart
Mar 23, 2008 | HP Compaq Presario C304NR Notebook
Acer Aspire 4720 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
