Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
My gas blower worked fine but quit during operation with no spark.
  • 420 Answers
Try a new spark plug.
Posted on Jun 04, 2010
Poulan gas blower quit running - like it was out of gas - now it will not start
i have the same problem, first chech spark and clean exhaust, probably it works; if not, the problem is on the crankshaft, because it moves the time of ignition coil
Apr 18, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
The other day it is running fine then all of a sudden it dies and won't start. air cleaner is clean. The a couple of days later, I start it and runs fine. I'm blowing off the patio and it dies again after...
If the air filter is clean, then you have either no spark or no gas. Gummed up carberators are well familiar with the leaf blowers. Once a year or every other year you should clean up your carb. During the winter season when your not using the blower, it is a good idea to put a 1/2 bottle of Stabil in the gas tank which will prevent carb gum-up while being stored.
You can remove the spark plug, put it back on the wire, lay the bottom of the plug next to a metal surface. Then pull the motor over while you observe for a good strong spark. If you have a good strong spark, then the problem is with the fuel.
If you have no spark, weak spark, or intermittent spark, then either the coil could be bad, plug could be bad, or you may even have a shorted kill switch.
Either no gas or no spark is your problem. Spark is easiest to check. If spark is good, remove and clean your carberator out thuroughly
Dec 31, 2010 | Garden
Blower hard to start no power
Did you implement, the choke during operation, or did you how about troubleshooting your gas mixture? what kind of oil did you use, is the spark plug sparking?
Dec 14, 2009 | ECHO, Inc. PB-251C Handheld Blower
Was working fine, then started to work at half force then just quit. Good fuel supply.
Try checking the fuel filter and try the air cleaner, if this is a mixed gas rig you may have the gas mix wrong. Pull out the spark plug and look to see if it's wet. if it's wet you have to much oil, if it's a 4 stroke you have a air problem, after cleaning out the air cleaner and drying the plug ans lightly sand the tip of the spark plug and wash off, try starting it, if it starts and runs your good to go, be sure the governor control arm has not fallen off the governor control arm. If you need more help just post a reply back.
Nov 22, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Was running fine and just quit..checked it and found no spark
Assuming the spark plug is good, it is probably the ignition module.
Jim
Jun 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Quit working during operation
easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark
Nov 20, 2008 | Poulan Featherlite Gas Blower, with Low...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
183 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
