Question about Kitchen Ranges
The sparker for the gas hob on my Baumatic B144SS is not working, yet the electricity is on and both the light and fan are working! Is there any way I can get it to work?? Cheers
    Champion:
  • 207 Answers
You need to clean up burner and the sparker head from dirt which acts like isolator and prevent spark to jump. Burner must have metal to metal contact with the range casing in order to work. Grease, oil and burned liquids like milk act like isolators and prevent contact between burner and the casing (mass).
Just unplug the range from the wall, take off burner, scrub and wash off all the dirt from it and from its seat to the very metal. Dry it out completely and put back in place. Plug in the range and give it a try.
Posted on Apr 09, 2008
How to fix the main oven in our Baumatic range cooker?
Although elements look in one piece they can go 2 ways, short circuit (visible normally by a bulge or tear) or the resistance gets way too high, They should normally be around 30 ohms resistance reading. Use a multimeter and check the ohm's reading of the element
Apr 08, 2014 | Baumatic Ovens
Baumatic B144SS Oven Not Heating Up.
You can test elements with a ohm meter. Cleaning temps get extremely high and will often damage an ovens electronics
Nov 16, 2017 | Baumatic Ovens
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Baumatic Ovens
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Kitchen Ranges Logo
114 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
