I have a 2 story house and at one end my outlets stopped working,nore does any of the bathroom out lets.the other side of upstairs work plus the downstairs work what the heck happened?????anyone please help.thank you.
  • oldguy5 Jun 04, 2010
    Obviously this isn't a washer problem. I'd check the circuit breakers and/or fuses in the circuit panel.
    Sergeant:
  • 363 Answers
Have you checked you breakers? If the breakers are working and all connected, you have a problem only a licensed electrician should deal with.
Posted on Jun 04, 2010
There are 2 GFI plugs in the rv. I found the one in the bathroom where is the other one?
Have you checked the outside plug? Next to the outside kitchen, It should be there. On my RV I have one next to the bathroom and outside.
Nov 28, 2015 | Keystone 2015 Outback Terrain 210TRS
We have a 2013 aspen trail 3117rids and the outlet in the kitchen counter area, the out let on the island and the gfi in the bathroom don't work. ?
Have you done a VOM test on the house lines to the bath from the circuit breaker box? This is important, without the GFI in place, just the bare wire test? If you have voltage from the box to the Bath wires, then your power is correct and the attached outlet needs to be checked for continuity. If no power to the bath from the box, the circuit breaker may be bad, or tripped.
May 09, 2014 | Dutchmen RVs
The clunking noise you can hear is also happening in my bathroom as a result of the washing machine clunking. The bathroom is upstairs and at the other end of house. An engineer came out today because
Sounds like the bearing in the drum is bad,may have to replace whole drum,bearing in it may not be replaceable,to find out,call appliance company and have them look your model number and see if drum is a whole unit or bearing can be replaced.
Oct 30, 2012 | Washing Machines
My wife pushed the ice dispencer then power went out tried plugging into other outlets yet nothing
Do the other outlets you plugged it into have power and something else plugged into them work such as a toaster /blender ect?? if all outlets in kitchen out their probably is a GFCI type outlet that has the reset button on it. Sometimes their in the kitchen or depending how the house was wired when built they could be in a bathroom or even garage. One outlet has that reset button but could have up to 6 outlets wired to it
Aug 16, 2011 | LG LSC26905TT Side by Side Refrigerator
Fri. I get home from work and wife says no hot water. I tripped the breaker and still no hot water. I then replace the breaker and still no hot water. I'm thinking I have a power problem between the...
Check to see if there is a GFI outlet in the house or garage. Reset if tripped. My wife would trip the GFI in the garage when she used the hair dryer in upstairs bathroom.
Apr 24, 2011 | TitanNet TITANTANKLESS. COM PRESENTS THE...
My mastercool blows out hot air upstairs
The one on top probably has no water in it or the pump is not working. Look closely at the front to ascertain if water is being pumped.If not turn electric off and remove one of the side panels with a 1/4 driver. In the reservior there should be water. If not you need to turn water on to unit or adjust/replace float. Also is it's warmer than 100 degrees outside you're unit might be fine...it has limitations.
Jul 09, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
Washing Machines Logo
Top Washing Machines Experts
