Question about Dell Dimension 8200 PC Desktop
My dell dimension 8200 desktop will recognize my harddrive but will not boot windows. the harddrive is from my compaq pesario.they were both made in 2001. dont have the dells original harddrive
  • 185 Answers
Well what you may have to do is insert the Windows installation disc and repair the system, (do not re install the operating system), insert the disk and re start the computer and when it asks you what to do click on repair my system after that you may have to get the drivers for your dell at: dell and that may work if it doesn't then you would have to re install the Operating system.
if it works for you, don't forget to rate me
thx
Posted on Jun 03, 2010
    Guru:
  • Dell Master
  • 1,705 Answers
You have to re-install windows. The current copy is looking for a Compaq and can only find a Dell.
Dell dimension 8200 boots up normally then after 20 mins beeps like an alarm is sounding then shuts down. i have disabled everything on start up , and also booted it up in safe mode , but i still have the...
Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check. Also open back cover of cpu then reconnect the RAM memory and both connection to harddrive make sure motherboard is not ground with cabinet.Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 11, 2010 | Dell Dimension 8200 PC Desktop
When i turn my dimension 8200 on it will not boot i keep getting the black screen with the safe mode option but if i choose the start windows normally option it goes to the blue screen telling me to check...
Your operating system or Master Boot Record is corrupt. Which version of windows are you using?
It may be possible to repair the problem with your windows disk. Boot from the Windows disk but make sure you read the instructions for windows repair carefully because some options will format your hard drive.
To rescue the data here are some things I do:
Make a boot disk with USB support and transfer the contents of your drive ton an external harddrive. Or, you could place your hard drive in another computer as a slave drive and retrieve your files that way.
Mar 28, 2010 | Dell Dimension 8200 PC Desktop
When i turn my dimension 8200 on it will not boot i keep getting the black screen with the safe mode option but no matter option i choose it aslways comes back to the black screen
if you have the windows xp disk, boot from it by pressing F12 upon turning on your computer. press 'R' to choose recovery console. you might be asked which windows installation you want to start, just press 1. when you see the console, enter the command 'fixboot' without the quotes. then type exit to restart your computer. hope it helps.
Mar 14, 2010 | Dell Dimension 8200 PC Desktop
Pc keeps rebooting and wont even go to safe mode
the os on the harddrive is not recognising the hardware and could be caused by change in bios settings or bad os.
Jan 24, 2010 | Dell Dimension 8200 PC Desktop
I closed my business last month and my desk top dell dimension was networked with microsoft xp pro and i want to take the hard drive from that somputer and install it in my home computer which is a stand...
HI,
When you remove the harddrive from a computer and plug it into a different machine though of the same model.It would not boot, because the operating system product key is unique to the machine. If you want to use this particular hdd in your home system, make it a secondary harddrive or reload windows on the harddrive again. But doing so , you would remove everything from the harddrive.
Thanks for using Fixya
Proton
Nov 07, 2009 | Dell Dimension 4600 PC Desktop
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Restore factory settings
If after hit control F11 nothing happen, probably you don't have a restore partition. Check that first.
If not you need to reformat your drive by reinstalling windows (you DO have that cd) and then reinstall the additional software that came with your 8200 (all that stuff is downloadable from dell website)
Nov 19, 2008 | Dell Dimension 8200 PC Desktop
My Dell Dimension 8200 will get to the screen where you select a user, after you select a user it will go to a blue screen & get stuck. What can I do? I have lost my reinstall disk & boot disk.
Try slecting the F7, F8 OR F9 key when it is booting up, if you can get to this screen choose, boot with last known good configuration. Let me know how you do.
Nov 11, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
97 people viewed this question
Alun Cox
