Question about GE GSS25SGSSS Stainless Steel Side by Side Refrigerator
GSS25SGSSS Ge Side by side GSS25SGSSS was working fine and when we got back from the memorial break, the front panel controls seem dead. if the bulb is in the socket the water dispenser and ice dispenser controls dont work. Sometimes they blink or turn of. Without the bulb the water dispenser eventualy works, the ice dispencer spins then stops. I think there is a short somewhere. i saw also that it may have resorted to display mode how do i change that?
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
  • 219 Answers
SOURCE: I have a GE Profile side by side. The icemaker & water dispenser
check where the line connects at the bottom of frezzer door
Posted on Mar 24, 2009
  • 1606 Answers
SOURCE: ice dispenser won't work, light won't side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Posted on Sep 12, 2009
  • 103 Answers
SOURCE: GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Posted on Oct 10, 2009
Water will not come out of the dispeners
g.e. has problems with the water line freezing up in the freezer door,if you're still having problems write me back and i'll help you out.
Dec 20, 2013 | GE GSS25SGSSS Stainless Steel Side by Side...
Serial # FL442725 GE stainless steel is not running. Light is on but the motor or digital numbers do not appear on the digital display window.
sounds like you have an electrical problem with either your display or main control board. Your more than likely going to have to contact a tech for more assistance (in person)
Aug 09, 2013 | GE GSS25SGSSS Stainless Steel Side by Side...
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
GE TPG24BF Not Defrosting
replace the white sensor located on the top of the evaperator coil
May 10, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Ice & water dispenser not working
The control board is likely gone bad or a wire harness inside the front came loose. With all those indications, I'd lean toward a dead board.
Jan 07, 2007 | GE PSW26SGRSS Side by Side Refrigerator
Freezer works, fan works, fridge side not getting cold
Whip, make sure the condensor fan is running in back. It should be running anytime the compressor is running. Check to see if you have a buildup of frost on the back of the freezer panel, this could indicate a defrost issue. This refer is controlled by one main mother board in back. Check these things first and post back. You may have to do some tests on the back.
Nov 24, 2006 | GE GSS25JEM Side by Side Refrigerator
GE GSS25SGSSS Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
