Question about Pioneer DEH-P6400 CD Player
I wont the speakers hooked to the cd player no the amp
I have a pioneer DEH-P6400 in my car. It works just fine. the people who had it installed hooked the speakers to the amp. In wont to run the speakers back to the cd player so i can have more room for more subs?? Can you help me??
    Guru:
  • 403 Answers
Check were the speakers are installed for pre existing wiring they probly left it there.. if not then you will have to run speaker wire from your stereo wiring harness to your speakers. if the speakers were hooked up to the amp then the wire in the harness should be vacant and you can use it if all the wires are connected then that means that you just have to find were that wire leads and hook your speakers up to it.
Posted on Jun 03, 2010
Testimonial: "Ok ill check and see the people whoo did it are idiots"
I need a wiring diagram for a pioneer deh-p6400.. please help..
red - 12v battery
yellow- 12 ignition
black- ground
blue/white- amp turn on
white FL+
white/black FL -
gray FR +
gray/black FR -
green RL +
green/black RL -
purple RR +
purple/black RR -
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
I have a Pioneer DEH-P6400 head unit. I need a wiring diagram so i can reinstall it.
the standard radio diagram is
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u
Aug 13, 2010 | Pioneer DEH-P6400 CD Player
My Pioneer car stereo stops all audio signal after a couple of minutes regardless whether i'm playing a CD or the radio, but the stereo stays on. and the CD seconds and minutes still count, do you know why...
Check your connections to your speakers and amp and look for loose wires touching metal. I believe your stereo is fine, this has something to do with your speakers and the speaker wire
Jun 07, 2010 | Pioneer DEH-P6400 CD Player
I need a wiring color code for a pioneer deh p6400 stereo deck ex i need to know what each color goes to ex. which color is the constant which is right speaker + etc
constant is yellow . switched ignition is red. ground is black. amp remote is blue white. illumination is orange. speakers are gray front right. white is front left. green is rear left. purple is rear right. all speaker wires have a match with a black stripe.black stripe is negitive
Feb 07, 2010 | Pioneer DEH-P6400 CD Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Wiring A Pioneer DEH P6400
If the factory harness is still in tact, you can buy an adapter at Best Buy for about 20$ or ask to see one and write down the pins and wires then match it up and cut n splice to your new deck. Hope this helps
Aug 17, 2009 | Pioneer DEH-P6400 CD Player
I need the wiring diagram for the Pioneer CD player model DEH P6400
Red= acc 12v
Yellow = constand 12v
black = ground
blue/white = remote turn 12v out.
purple pairs are the Right rear speaker
Grey pairs are the front right speaker
white pairs are the front left speaker
green pairs are the left rear speaker
orange white is the dimmer.
Mar 17, 2009 | Pioneer DEH-P6400 CD Player
86 buick century
go to a car stereo store and buy an adapter plug it will plug into the plugs in your dash then all you have to do is match the wire colors from your radio to the colors on the adapter..........i believe some walmart stores carry these
Dec 27, 2008 | Pioneer DEH-P6400 CD Player
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Pioneer DEH-P6400 CD Player Logo
129 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
