Question about Kenmore 64802 Top Freezer Refrigerator
Hello\r\nI am trying to troubleshoot my Kenmore Refrigerator
Hello I am trying to troubleshoot my Kenmore refrigerator problem. Model # 106.9751751
The refrigerator is not cooling but the freezer is working fine.
I did search and found some tips on what to do on the drain line icing up.
So, I went in to the freezer compartment and removed the bottom panel and back panel where I did find ice buildup but not on the coils.
I used a hair dryer to remove the ice buildup and also the drain line.
After cleaning up the excess ice/water, I put the pieces back together and turned the unit back on.
I notice that the freezer began cooling and went down to freezing temps rather quickly.
I checked the refrigerator temp this morning and it is still around 60 degrees.
I noticed that a couple of parts may need to be replaced –
-defrost timer
-defrost thermostat
Can you confirm that these may be the parts I need to replace or if I need to check something else?
    President:
  • 1,430 Answers
If the coils are not icing up you do not have a defrost problem. Check that the evaporator fan is operating. Thats the one near the coil. You will need to close the door switch to see if it comes on. If it is working next check that the damper is opening this alows cold air into the fresh food section. Without the full model # I am not sure if your defrost thermostat operates the fan. Check the wiring diagram to see if the t-stat feeds the fan. If it does and there is no power at the fan replace the t-stat.The problem is likely to be either the fan or damper motor. Try this link for more testing info
http://appliancehelponline.com/sxsevapfan.html
http://appliancehelponline.com/sxsdamper.html
http://appliancehelponline.com/sxsdefrosttstat.html
Posted on Jun 03, 2010
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
The support condiment of my door is broken.
That sounds like a Kenmore Canadian model number. Contact Sears parts in Canada and give them your model number and ask them about a part replacement I'm limited here in the US to answering your question the reason I have no documents on your model numbers
Nov 18, 2015 | Kenmore Refrigerators
How can i get a manual for my kenmore 596.58695890
Hello bmarshall196,
I was not able to find a free manual online for your refrigerator. The only one that I could find was at sears parts direct for $21.41 at the following link: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-59658695890/0582/0165000?pathTaken=&prst=0&shdMod=59658695890
Apr 07, 2011 | Kenmore Refrigerators
Kenmore refrigerator model 106.54592400 wont cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 16, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Nov 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator is not cooling
Hello hazraan
Welcome.
You said your Kenmore model 60852990 freezer is working but refrigerator is not cooling.
Lets try a couple of ideas.
Is your freezer filled up where the packages are covering the air vents in the rear of the freezer?
Refrigerators and freezers must share the cold air and circulate between them. If the freezer is packed full with not enough space at the air vents in side it, the fridge will get warmer!
Next,Turn off the fridge and freezer controls, and then go to the breaker box and turn off the breaker to the fridge for 5 minutes!!!!!
Then restart it and the fridge and freezer controls.
This should reset the system and solve the problem. let me know if either were the case.
If either was the reason,it now will take some 8 to 12 hours to gets back to temperature.
Waiting your response.
Huuum, Please remember to leave a rating.
Oct 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cubic feet size of Kenmore refrigerator
Yes, I found something on amazon, here: Amazon com Kenmore refrigerator manual I hope this was helpful. Cheers
Aug 03, 2008 | Refrigerators
Kenmore 64802 Top Freezer Refrigerator Logo
170 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
