Question about Ricoh Aficio 450 Copier
HOW DO I CLEAR FUNCTIONAL PROBLEM SC320 ON RICOH 1018D
  • Ricoh Master
  • 1,297 Answers
It is the polygonal mirror error code.Inspect the polygonal mirror motor,the connection between the motor and BICU unit,the cable and BICU unit.For reset turn the copier main switch OFF disconnect the main cable,wait 1 minute,connect the main cable and turn ON the copier..
Posted on Jun 05, 2010
I need help the 11+17 paoer is always jaming from the slip tray.also it is not picking up the said paper from the tray.
Posted on Jun 10, 2010
Error message: sc320 can I replace it myself?
sc320 mostly defective in polygon motor you can change by your self if you know how to remove the laser unit , it easy .
Jan 06, 2011 | Ricoh Aficio 1018D Copier
Error sc320
you have to replace polygon motor
Sep 21, 2010 | Ricoh Aficio 1018D Copier
When you put the machine on this is the error you see SC320
Polygonal mirror motor error.
You will have to replace the Polygonal mirror motor.
Feb 20, 2010 | Ricoh Aficio 1018D Copier
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Functional Problem on our Ricoh 1018D
Enter SP mode - Clear (yellow) key, 1 0 7 and hold and press stop (orange) key for 3 seconds.
Enter SP 5-810 (SC code reset) and
select “1”. Then switch off and on the machine.
If error still there, probably you have one of the following faulty;
Fusing thermostat open,
Fusing thermistor open or defective,
Fusing lamp open or
Power supply board defective.
Please, first check fusing lamp and thermostat for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Aficio 1018D Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Code SC320
i'd exprience the same problem once. what i did was to change polygon size laser. its working perfectly now
Oct 31, 2007 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
811 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
