Question about Sony Ericsson Walkman® W995 Cell Phone
My handphone speaker can't make a sound,it has a problem.
When i switch on the music or a radio the speaker has a problem,it can't make any sound from my handphone.
My ipod plays songs and i can hear the music but when i switch to radio there is no sound speakers do not work on radio..what is wrong????
Hi Fay
You need to clarify what you are saying....
Your iPod plays songs and you can hear music?
Where is sound coming from... Earphones?
How do you switch iPod to Radio....
Is there a cord connecting both together?
I would then suspect cord or connector type not matching up with radio input connector.
Connectors can be Sterio or Mono
Look at spacing on connector....
Earphone Adapter may help here
Mar 03, 2015 | Audio Players & Recorders
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
Manual for WS-A8 mini portable music loud speaker with fm radio
pretty simple, turn it on for radio, hold mode utton for 2-3 seconds to switch to speaker mode. if u turn it off and turn it again on, it will always start in a radio mode! thats all
Jun 16, 2013 | dealeurstore.com WS-A8 Mini Portable Music...
Dwarf 360 omni directional sound manual
how do i get the music to play do i have to download anything to the speaker there is music on the sd card but wont play
Aug 30, 2012 | Mighty Dwarf Black Authentic Vibration...
Cannot play music after format
go 2 now playing mEnu Then selEct update library..if i dosenT work theN il give another way..
Dec 24, 2011 | Nokia Classic 2700 Cell Phone
My Music in my car is not playing from the speakers.
I had the same issue in a Ford Explorer. I switched out the factory amp in the back and the sound returned. I feel that you are having the same issues I did. Good Luck
Feb 16, 2010 | Dynaudio System 240GT Car Component System
Hyundai sona98A radio and audio do not work
Radio has static on the AM station, also radio does not have good sound coming from speakers. I have tried to tune the radio but it still sounds very monotune The music coming from Radio sound bad.
Dec 08, 2008 | Car Audio & Video
Installed a clarion radio it powers up but no music thru speakers
sounds like a short in your wiring to your speakers the best thing to do to check this is run a speaker wire directly to the speaker from the stereo check it that way and see if it works.If that don't work it's the wires on the stereo connection.The speaker wires on most aftermarket stereos are mostly colored 2 of each green,purple,white & grey.
Nov 09, 2008 | Clarion DB538RMP CD Player
Panasonic SA- AK 133 Music system sorround system not working
this is something a tech expert on electronics can handle. even replacing parts has to be attended by a pro-technician. something is wrong with your DSP processor or system components. it could be the switch only or it could be the processor.
Mar 29, 2008 | Audio Players & Recorders
JVC CH-X1100RF
Look for a loose connector on the back of the radio. If it is not fully seated in the radio, all sorts of goofy problems happen.
Apr 15, 2017 | JVC CH-X1100RF 12-Disc CD Changer
Sony Ericsson Walkman® W995 Cell Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
